Force applied to a mass of an inclined plane with mass
The discussion focuses on calculating the force applied to a mass (m) on a frictionless inclined plane (wedge) of mass (M) at an angle (θ). The derived equation for the force is F = -mgsin(θ) + Mgsin(θ), where the first term represents the gravitational force on mass m and the second term represents the normal force from mass M. The normal force must be equal and opposite to the perpendicular force acting on mass m, ensuring that the net force in the y-direction equals zero while allowing for acceleration in the x-direction. This analysis is crucial for understanding the dynamics of objects on inclined planes.
  • Understanding of Newton's laws of motion
  • Familiarity with free body diagrams
  • Basic knowledge of trigonometry, specifically sine functions
  • Concept of normal force in physics
  • Study the principles of inclined plane dynamics in classical mechanics
  • Learn about free body diagram construction for complex systems
  • Explore the effects of friction on inclined planes and their calculations
  • Investigate the role of acceleration in multi-body systems
Physics students, educators, and anyone interested in classical mechanics, particularly those studying forces on inclined planes and the dynamics of multi-body systems.
JordanGo
There is a box of mass m on a wedge of mass M with angle θ (the triangle also has a angle of 90 degrees). I need to find the force applied on the little mass, this is what I got:
F=-mgsinθ+Mgsinθ
Where the first term refers to the force of gravity applied to the mass m and the second term refers to the normal force applied on m by M.
I think my mistake is the normal force because looking at the limits when M is really big, the mass m moves in the opposite direction that gravity pushes it.
Can someone help me set this force up?
P.S. the surface of the wedge is frictionless and the surface in which the wedge lies on is frictionless.
your mistake is that the normal force acting on the box should be equal and opposite to the force acting on it that is perpendicular to the surface that it's resting on
look at a simple example: box sitting on the ground, no angles
there is the force of gravity acting on this box, which is -mg
the normal force therefore is equal and opposite to the force of gravity, which in this case is also perpendicular to the surface
so the normal force acting on this block is +mgan important thing to remember is that if an object is not moving or has a constant velocity, then the sum of the forces acting on that object need to equal zero.
This also applies for each component of the force. What that means is that if the box is not accelerating in the x direction, then the forces in the x direction must add up to be zero. And the same thing in the case of the y direction.
So, if we look at your example, we see a block on a wedge. Sometimes it helps to think about things in terms of common sense: if you put a block on a wedge, what would happen to the block. Obviously it would slide down the wedge.
So let's say that the y direction is perpendicular to the surface of the wedge, and the x direction is parallel to the surface of the wedge. And by surface I mean the surface on which the block is sitting.
If we think about it this way, we can see that there will be no acceleration in the y direction, but there will be acceleration in the x direction. There's no acceleration in the y direction because... well it's not like the block is going to fly off the wedge or fly "into" the wedge, that would make no sense.
Therefore, the forces in the y direction need to add up to zero.
But the forces in the x direction should *not* add up to zero.
  • · Replies 36 ·
  • · Replies 25 ·
  • · Replies 20 ·
