Solving Water Stream Problem: Height of Wall Impacted
  • Thread starter Thread starter ProBasket
    Stream Water
The discussion revolves around a physics problem involving projectile motion, specifically analyzing the trajectory of water exiting a hose nozzle at an angle and its impact height on a vertical wall. The original poster has successfully solved the first two parts of the problem but seeks assistance with maximizing the height of the water on the wall by adjusting the nozzle angle.
  • Participants discuss the use of calculus to derive a function relating the height of the water on the wall to the angle of the nozzle. There are attempts to clarify the process of maximizing this function and finding the optimal angle.
The conversation includes various attempts to derive the correct equations and differentiate them to find the maximum height. Some participants provide hints and corrections regarding the differentiation process, while others express confusion about the steps involved.
There is a mention of specific values and conditions, such as the initial speed of the water and the distance to the wall, which are relevant to the calculations but not fully detailed in the discussion. The original poster is preparing for a test, indicating a time constraint and a need for clarity in the explanations provided.
ProBasket
a stream of water exits from the nozzle of a hose at a speed of 16m/s. the vertical wall of a burning building is a horizontal distance D=4.0 m away from the nozzle. I understand and got the correct answers for the first two questions, but i need help on the third question.
1.) if the nozzle is pointing at an angle of 40 Degrees above horizontal, how long does it take for the water to travel from the nozzle to the wall? 0.33s (it's correct, no need to check)
2.) At what height above the nozzle does the water hit the wall? 2.8 m ( this is also correct)
ok, I'm stuck on the third question...
3.) If the angle of the nozzle is changed to maximize the height of the water of the wall, what height above the nozzle does the water hit the wall?
The thing i don't understand is finding the angle of the nozzle when it's changed to the maximize height of the water. can someone help me?
Do you know calculus...?If so,then compute the function height on the wall vs.angle, then maximize this function and then compute the maximal value...
Daniel.
i do know calculus, but i don't know what you just said. please explain with details. the answer is 12.8m, but i don't know how to get that answer. I'm trying to study for a test, so any help is appreciated. maybe if you explain it in a non-math/less math term, i would be able to understand.
"compute the function height on the wall vs.angle"
how would i do that?
The equations of motion are simple to get,by applying the second law of Newton for constant gravity field.
[tex]x(t)=v_{0}\cos \theta \ t[/tex]
[tex]y(t)=v_{0}\sin \theta \ t-\frac{1}{2}gt^{2}[/tex]
Put the condition that the water flow reaches the wall at the height "h" and then eliminate "t' between the 2 equations.You'll end up with an equation h=h(\theta).
Post that equation,please...
Daniel.
[tex]h = \frac{v(0)^2*sin(theta)^2}{2g}[/tex]
this one?
Nope,that's 2 simple...Another one,please...
Daniel.
HINT:It contains tangent & secant squared.
h = tan(theta)*D-1/2*g(D/vo*cos(theta))^2
Perfect,now maximize & extract maximum value (don't bother computing the 2-nd derivative to convince yourself of the maximum value)...
Daniel.
"maximize & extract maximum value" <--- what do you mean?
do you just want me to plug in the values and find h?
if so, h = 3.17
No, find [itex]dh/d\theta[/itex], and set this to zero. That will give you the optimal [itex]\theta[/itex]. Plug this into find h.
Besides, how did you get that number without knowing the optimal angle ?
i got
[itex]dh/d\theta[/itex] = [tex]d(sec^2(\theta)+ \frac{d*g*cos(\theta)*sin(\theta)}{v_0^2})[/tex]
so I'm trying to solve for theta right?
is this correct so far?
It is incorrect.Pay attention with the differentiation of [itex]-\frac{1}{\cos^{2}\theta}[/itex]
Daniel.
Also, you seem to have squared the velocity in the denominator.
It was supposed to be squared,Gokul.
Daniel.
Oops sorry...ignore that.
  • · Replies 18 ·
  • · Replies 32 ·
13K
