How Does the Biot-Savart Law Apply to Two Perpendicular Current-Carrying Wires?
The discussion revolves around the application of the Biot-Savart Law to two perpendicular current-carrying wires. The original poster describes a scenario with two long, straight wires carrying currents and seeks assistance in determining the magnetic field at a specific point due to both wires.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster expresses uncertainty about calculating the combined magnetic field from two wires, having a clear understanding of the magnetic field from a single wire. Some participants suggest considering the vector addition of the magnetic fields from each wire.
Participants are exploring different interpretations of the problem, with some offering hints about vector addition and others providing informal analogies to understand the direction of the magnetic fields. There is no explicit consensus on the approach yet.
The original poster mentions specific values and configurations for the currents and positions of the wires, but there is a lack of clarity regarding the exact nature of the currents involved, particularly for the second wire.
andrew410
Two very long, straight, parallel wires carry currents that are directed perpendicular to the page, as in the figure below. Wire 1 carries a current I1 into the page (in the -z direction) and passes through the x-axis at x=+a. Wire 2 passes through the x-axis at x=-2a and carries an unknown current I2. The total magnetic field at the origin due to the current-carrying wires has the magnitude (2*permeability of free space)/(2*pi*a) The current I2 can have either of two possible values.
I know how to get the magnetic field at a point P for one current carrying wire, but I don't understand how to get the magnetic field at a point P for two current carrying wires. I know that the magnetic field at a point P for one current carrying wire is B=(permeability of free space * I)/(2*pi*a).
I need some help...Any help would be great. Thx in advance!
HINT:Add them as vectors...Meaning the two distinct contributions from each current/wire...
Daniel.
P.S.It's not Biot-Savart(-Laplace) law here...It's more like Ampère...
Point your "thumb" in the direction of the flow of current and curl your four fingers around the wire (just like when you jack off), the direction of your four fingers is the direction of the magnetic field, do the same for the other 2nd wire. If one time your fingers point clockwise and other time anticlockwise then subtract the magnetic field othewise add.
logicalman said:
Point your "thumb" in the direction of the flow of current and curl your five fingers around the wire (just like when you jack off), the direction of your five fingers is the direction of the magnetic field, do the same for the other 2nd wire. If one time your fingers point clockwise and other time anticlockwise then subtract the magnetic field othewise add.
Does that mean that u assumed he/she has 6 fingers at one hand (at least)... :confused: :-p
Daniel.
