Need help proving limit does not exist
  • Thread starter Thread starter mathie_geek
    Limit
The original poster seeks to prove that a limit does not exist for the function f(x,y) as (x,y) approaches (0,0). The function is defined as f(x,y) = (|x|^a * |y|^b) / (|x|^c + |y|^d), where a, b, c, and d are positive numbers, and the condition a/c + b/d ≤ 1 is given.
  • Exploratory, Assumption checking
  • Participants discuss various approaches to evaluate the limit, including substituting y = mx and exploring paths such as y = x^(c/d). There are attempts to simplify the limit using different powers for x and y, and questions arise regarding the implications of the inequality involving a, b, c, and d.
Some participants have provided hints and suggestions for alternative paths to explore, such as using specific substitutions for x and y to potentially reveal a nonzero limit. There is ongoing exploration of the conditions on a, b, c, and d, with some participants expressing uncertainty about their calculations and the implications of the inequalities.
There are discussions about the restrictions on the parameters a, b, c, and d, particularly regarding their relationships and how they affect the limit's existence. The original poster and others are trying to clarify these conditions while working through their attempts to find the limit.
mathie_geek
I need to prove a limit does not exist for f(x,y) as (x,y) -> (0,0). I already tried approaching from y=mx and I got the limit 0.
f(x,y) = ((|x|^a)(|y|^b))/((|x|^c)+(|y|^d)) where a,b,c,d are positive numbers and a/c+b/d ≤
I got limit = 0 approached from y=mx.
I can't use Squeez Theorem either. How should I approach this question? Just a hint would be good. Thanks!edit: Sorry, missed a + sign in the denominator!
f(x,y) = ((|x|^a)(|y|^b))/((|x|^c)(|y|^d)) where a,b,c,d are positive numbers and a/c+b/d ≤ 1
I can't use Squeeze Theorem either. How should I approach this question? Just a hint would be good. Thanks!
Hello mathie_geek. Welcome to PF!
Edited:
[STRIKE]I assume your function really is:[/STRIKE]
I see you corrected it to be:
[itex]\displaystyle f(x,y)=\frac{|x|^a\,|y|^b}{|x|^c+|y|^d}\ .[/itex]
Thanks!
Trying to learn how to input functions :P
I missed a + so denominator is |x|^c + |y|^d
mathie_geek said:
Thanks!
Also, what is the restriction on a/c & b/d?
Is it as you said, [itex]\displaystyle \frac{a}{c}+\frac{b}{d}<1\,,[/itex]
[STRIKE]or is it[/STRIKE] [itex]\displaystyle \frac{a}{c}<1\ \text{ and }\ \frac{b}{d}<1\ ?[/itex]
Added in Edit:
Never mind, I see that it must be as originally stated.
It's (a/c)+(b/d) <= 1
can anyone help
Hint: try setting x = t^p, where p is some power, and y = t^q, where q is some other power.
I got lim y->0 ((|t|^ap)(|y|^b))/((|t|^pc)+|y|^d)) = 0
and lim x->0 ((|x|^a)(|t|^bq)/((|x|^c)+(|t|^dq)) = 0
Did I do something wrong?
Are there conditions on a, b, c, and d? If a+b is not larger than c+d you will NOT get "0" as limit for y=mx.
No, I meant that you should pick appropriate values for p and q (in terms of a, b, c, and d) which will give you a counterexample. Hint: try to choose values which will get rid of the exponents in the denominator.
This will transform the problem into a limit involving a single variable, t. Then let that variable t approach zero. By doing this, x and y will approach (0,0) along a certain curve, instead of a straight line. If you do it right, you can get a nonzero limit.
ok, I tried x = t^(d/c) and y = t^(c/d) as two different limits so I got:
lim y->0 (|t|^ad/c)(|y|^b)/((|t|^d)+(|y|^d))
lim x->0 ((|x|^a)(|t|^bc/d))/((|x|^c)+(|t|^c))
those both =0 though.
I'm sorry I'm not that good at this.
Do you mean to put both of the substitutions into one limit of t->0?
a/c <= 1-(b/d)
No, try to choose powers which will make the exponent in both terms of the denominator equal to 1.
Yes, make both substitutions at once, and then take the limit as t->0.
m_geek,
Try letting (x, y) → (0, 0) along the path [itex]\displaystyle y=x^{c/d}\ .[/itex]
That makes the denominator be fairly well behaved. I haven't checked it beyond that.
OH, I let y= t^(1/d) and x=t^(1/c)
so that lim t->0 (|t|^a/c+b/d-1)/2
and since a/c+b/d-1 <= 0,
then the limit would be 1/2 if a/c+b/d-1=0 or does not exist if a/c+b/d-1< 0.
since the two limits do not agree, limit d.n.e.
Is this correct? :D
SammyS said:
m_geek,
I tried that but I don't know why it didn't work out for me because I kept getting 0 as the limit..
Let's see your work for this, because it did work out for me & the limit is not zero.
I let ##y = x^(c/d)##
so that it simplifies to ##(|x|^ (a+(bc/d)))/2(|x|^c)##
which as x->0 limit becomes 0/2 ? I'm not sure how to take into account the inequality of a,b,c,d though
mathie_geek said:
I let ##y = x(c/d)##
so that it simplifies to ##(|x|^{a+(bc/d)}) /(2(|x|^c))##
I have fixed your Latex above, and repeat it below, so you can see the code.
[itex](|x|^{a+(bc/d)}) /(2(|x|^c))[/itex]
Now as a more readable fraction:
[itex]\displaystyle \frac{|x|^{a+(bc/d)}}{2(|x|^c)}[/itex]
Write that expression using |x| only once.
Remember, [itex]\displaystyle \frac{x^R}{x^T}=x^{R-T}\ .[/itex]
I got this after: [itex](|x|^{a+(bc/d)-c}) /{2}[/itex]
expanding the exponents I have [itex]\displaystyle \frac{acd+bc^2-c^2d}{cd}[/itex]
and given [itex]\displaystyle \frac{ad+bc-cd}{cd}<=0[/itex] which is 1/c of the exponent..
So then |x| has an exponent negative so limit d.n.e right? cause limit of 1/|x| as x->0 d.n.e
Actually, that's [itex]\displaystyle \frac{ad+bc-cd}{d}\le 0[/itex]
What if [itex]\displaystyle \frac{ad+bc-cd}{d}=0\ ?[/itex]
Now, maybe you can adjust the path so that the exponent is always zero.
Oh, I see. Since [itex]\displaystyle \frac{ad+bc-cd}{d}> \displaystyle \frac{ad+bc-cd}{cd}[/itex] then does that mean it HAS to = 0? If it's 0 then lim is 1/2
Let's go back to the exponent:
[itex]\displaystyle <br /> \frac{acd+bc^2-c^2d}{cd}=\frac{c(ad+bc-cd)}{cd}=\frac{ad+bc-cd}{d}\ .[/itex]​
I have no idea as to why you multiplied that by 1/c .
Unless you meant to say that "a,b,c,d are positive integers [STRIKE]numbers[/STRIKE]" (emphasizing integers, rather than numbers), the following inequality
[itex]\displaystyle <br /> \frac{ad+bc-cd}{d}>\frac{ad+bc-cd}{cd} \ \ \text{ is not true.}[/itex]​
The number, c, might very well be less than 1 if a, b, c, and d are not required to be integers.
All that I said was, if a/c + b/d ≤ 1, then [itex]\displaystyle \frac{ad+bc-cd}{d}\le 0[/itex].
If you choose the case of it being an equality, (choose the = sign), then the limit is defined, with said limit being 1/2.
However, that's far from being the general case for this expression.
  • · Replies 26 ·
