Diagonalizing a Matrix: Implications of Double Eigenvalues
  • Context: Undergrad
  • Thread starter Thread starter icetea555
    Matrix
The discussion revolves around the implications of encountering double eigenvalues when attempting to diagonalize a matrix. Participants explore the conditions under which a matrix can be diagonalized, particularly focusing on the relationship between eigenvalues, eigenvectors, and diagonalizability.
  • Some participants propose that having a double eigenvalue does not necessarily imply that the matrix is not diagonalizable, citing examples such as the unit matrix.
  • Others argue that a matrix is diagonalizable if there exists a basis of eigenvectors, which can be determined by examining the minimal polynomial and its factors.
  • A participant suggests that even with a characteristic polynomial like (λ+1)²(λ-5)=0, one must still find eigenvalues and their corresponding eigenvectors to assess diagonalizability.
  • Another viewpoint emphasizes that an n by n matrix is diagonalizable if it has n independent eigenvectors, noting that fewer distinct eigenvalues do not preclude diagonalizability.
  • Examples are provided to illustrate cases where matrices with repeated eigenvalues may or may not be diagonalizable, highlighting the need for independent eigenvectors.
Participants express differing views on the implications of double eigenvalues for diagonalizability, with no consensus reached on a definitive rule. The discussion remains unresolved regarding the conditions under which a matrix with double eigenvalues can be diagonalized.
Limitations include the dependence on the definitions of eigenvalues and eigenvectors, as well as the need for clarity on the relationship between characteristic and minimal polynomials.
icetea555
Hi
Can someone please clarify if you are trying to diagonalize a matrix and you find that one of your eigenvalue is a DOUBLE root, does that mean the original matrix is NOT diagonalisable.
Thanks
icetea555 said:
Hi
Thanks
No, it doesn't mean that. For example, the unit matrix of order n has the eigenvalue 1 with (algebraic) multiplicity n, and yet it
is diagonalizable...
A matrix is diagonalizable iff there is a basis (of the vector space we're working on) all the elements of which are eigenvectors
of the matrix iff the minimal polynomial of the matrix can be written as the product of DIFFERENT linear factors.
DonAntonio
DonAntonio
Thanks so much for your reply!
So what you are say is that even if I have something like...
(λ+1)^2(λ-5)=0
I still find the eigenvalues and solve the matrix to determine whether it is diagonalisable
right?
(λ+1)^2(λ-5)=0
right?
If you meant to ask whether you still have to find the eigenvalues AND THEN their respective eigenvectors and check whether
you have 3 (as I'm assuming that what you wrote is the characteristic polynomial) linear independent eigenvectors, then
the answer is yes: you still have to do that...or, since the minimal and charac. polynomials have the same irreducible
factors, you could check whether [itex]\,(\lambda+1)(\lambda-5)\,[/itex] is the minimal pol. of the matrix, since in this case
it'd be the product of different linear factors and thus the matrix is diagonalizable.
Yet since most questions/applications usually require knowing at least some of the eigenvectors, perhaps the first
method is more useful.
DonAntonio
Whether or not an n by n matrix is diagonalizable is determined by whether or not it has n independent eigenvectors. IF there are n distinct eigenvalues, then, because eigenvectors corresponding to distinct eigenvalues are independent, it follows that if an n by n matrix has n distinct eigenvalues, it is diagonalizable but if has fewer than n distinct eigenvalues, it may still be diagonalizable. To give a trivial example, the matrix
[tex]\begin{bmatrix}2 & 0 \\ 0 & 2\end{bmatrix}[/tex]
is already diagonal (so obviously "diagonalizeable") with the single eigenvalue 2 and the two independent eigenvectors <1, 0> and < 0, 1>.
[tex]\begin{bmatrix}2 & 1 \\ 0 & 2\end{bmatrix}[/tex]
has 2 as its only eigenvalue but now has only multiples of <1, 0> as eigenvectors so not two independent eigenvectors. That matrix cannot be diagonalized.
  • · Replies 33 ·
