Finding Time of Flight/Maximum Height/Horizontal Range
  • Thread starter Thread starter ZeshShawn
    Range Time
The discussion focuses on calculating the Time of Flight, Maximum Height, and Horizontal Range of a projectile given a Launch Angle and Initial Velocity of 25 m/s. The angles considered are 9°, 27°, 45°, 63°, and 81°. The correct approach involves decomposing the initial velocity into its x and y components using sine and cosine functions, and applying kinematic equations to derive the necessary formulas. The Time of Flight must be included in the equations to accurately determine the projectile's motion.
  • Understanding of projectile motion concepts
  • Familiarity with trigonometric functions (sine and cosine)
  • Knowledge of kinematic equations
  • Ability to decompose vectors into components
  • Study the derivation of projectile motion equations
  • Learn how to calculate Time of Flight for different launch angles
  • Explore the relationship between launch angle and range
  • Practice problems involving Maximum Height and Horizontal Range calculations
Students studying physics, educators teaching projectile motion, and anyone interested in mastering kinematic equations related to projectile trajectories.
ZeshShawn
Find Time of Flight/Maximum height & horizontal range given Launch Angle and Initial Velocity.
Using Launch angles: 9, 27, 45, 63 & 81.
Initial Velocity: 25 m/s
I used sine/cosine to find the Horizontal Range & Maximum height.
For launch angle 9°:
Maximum Height: 25sin9 =
Horizontal Range: 25cos9 =
I don't know if It's correct, also, I do not know how to find the Time of flight.
Please help.
Thanks.
That would not be correct.
if the launch angle were 9deg, then 25sin(9) would be the y-component of the velocity.You need to divide the initial velocity into x and y components.
Since the launch angle varies, you just leave it as ##\theta##.
From there - use kinematics to write out the maximum height and range equations in terms of the acceleration (you know this) in each direction and the velocity components.
You'll have to include an extra time of flight (T) term which you eliminate to get the final relations.
It is an important discipline in physics to be able to write down equations without knowing what parts of them are.
28K
