Solving systems of nonlinear ordinary equations in Mathematica.
The discussion focuses on solving a system of five nonlinear equations of degree 7 using Mathematica's Solve function. Users report that the computation runs for an extended period without yielding results. Suggestions include simplifying the equations by substituting common expressions, such as replacing (e-q) with a new variable, and identifying large common subexpressions to enhance performance. It is emphasized that solving complex multivariate polynomials may not complete in a reasonable timeframe without further simplifications or assumptions.
  • Familiarity with Mathematica 12.3 syntax and functions
  • Understanding of nonlinear equations and polynomial degrees
  • Knowledge of algebraic simplification techniques
  • Experience with multivariate polynomial systems
  • Learn how to use Mathematica's Simplify and FullSimplify functions
  • Research variable substitution techniques in Mathematica
  • Explore the use of assumptions in Mathematica's Solve function
  • Investigate optimization strategies for solving complex polynomial systems
Mathematicians, researchers, and engineers working with nonlinear systems, particularly those utilizing Mathematica for complex equation solving and optimization.
fab333
I'm trying to solve a system of five nonlinear equations (degree 7) in Mathematica:
Code:
Solve[{q (a^2 +
       b^2 (3 q^2 + r^2 + 8 t^2)) ((e - q)^2 - R^2 - 4 T^2)^2 +
    q ((e - q)^2 + R^2 + 4 T^2) - 2 (e - q) (r R + 4 t T) == 0,
  R (a^2 + b^2 (3 R^2 + (e - q)^2 + 8 T^2)) ((e - q)^2 - R^2 -
        4 T^2)^2 + R (R (R - r) - (e - 3 q) (e - q) + 4 T (T - 2 T)) -
     r ((e - q)^2 + 4 T^2) == 0,
  r (a^2 + b^2 (3 r^2 + q^2 + 8 t^2)) ((e - q)^2 - R^2 - 4 T^2)^2 -
    r (R^2 + (e - q)^2 + 4 T ^2) + 2 R (q (e - q) - 4 t T) == 0,
  T (a^2 + 2 b^2 (2 T^2 + (e - q)^2 + R^2)) ((e - q)^2 - R^2 -
        4 T^2)^2 + T (4 T (T - t) - (e - 3 q) (e - q) + R (R - 2 r)) -
     t ((e - q)^2 + R^2) == 0,
  t (a^2 + 2 b^2 (2 t^2 + q^2 + r^2)) ((e - q)^2 - R^2 - 4 T^2)^2 -
    t (4 T^2 + (e - q)^2 - R ^2) + 2 T (q (e - q) - rR) == 0
  }, {q, r, t, R, T}]
but the program is running for an hour...
there is hope that it get to the end?
How do I have to change it to hope to arrive at the conclusion?
Thanks
If it isn't just a simple scrape and paste error then this worries me
) - rR) == 0
Perhaps you want a space between r and R there.
Sometimes when you have very complicated expressions you can make a simplification that can speed things up. For example, you have dozens of (e-q) in your equations. If you could substitute emq for (e-q) everywhere, patch the few isolated remaining q with (e-emq) and see whether this resulted in enough simplification then it might help speed things up.
I would also look for large common subexpressions and see whether you might be able to find a way to substantially simplify this before throwing it at Solve.
In general I would expect throwing 5 seventh order complicated multivariate polynomials at Solve to never finish in an acceptable time or with an acceptable result.
Assumptions may help as well.
  • · Replies 19 ·
