Critical Points and Graphs of Differential Equations
The discussion focuses on the differential equation dy/dt = alpha - y^2, analyzing critical points based on varying values of alpha. For alpha < 0, alpha = 0, and alpha > 0, the critical points are identified and their stability is assessed as asymptotically stable, semistable, or unstable. Additionally, the solution for alpha > 0 is derived, and a bifurcation diagram is plotted to illustrate the relationship between critical points and alpha. Participants are encouraged to share their attempts to facilitate targeted assistance.
  • Understanding of differential equations and stability analysis
  • Familiarity with bifurcation theory
  • Knowledge of critical points in dynamical systems
  • Experience with graphing functions and interpreting plots
  • Study the stability of critical points in nonlinear differential equations
  • Learn how to construct bifurcation diagrams for various equations
  • Explore the implications of parameter changes on system behavior
  • Practice solving differential equations using numerical methods
Mathematicians, physicists, and engineers interested in dynamical systems, particularly those analyzing stability and bifurcation in differential equations.
nallapanther
Consider the equation dy/dt = alpha - y^2
a) Find all of the critical points. How does it change as alpha < 0, alpha = 0 or alpha > 0?
b) In each case of different alphas, consider the graph of f(y) vs y and determine whether each critical point is asympototically stable, semistable, or unstable.
c) For alpha > 0, find the solution.
d) Plot a bifurcation diagram - this is a plot of the location of the critical points as a function of alpha (plot a graph alpha as x-axis and y-axis showing the location of the critical point)
To get the best out of these forums, you should show us your attempt at the problem so we can target assistance to the place you most need it.
For example - do you know how the critical points of y are related to dy/dx ?
hey mate post up what you've done and i'll show you the next steps
the diff plots can be daunting in the beginning but if you keep practicing them they become very easy to interpret
let us know
  • · Replies 27 ·
