A group theoretic puzzle in solid geometry
The discussion revolves around the group theoretic properties of a regular dodecahedron, particularly focusing on its group of rotations and how these rotations can permute a specific collection of five objects associated with the solid. Participants explore the implications of these rotations in relation to the dodecahedron's geometric features, including faces, edges, and vertices.
  • One participant describes the group of rotations of a dodecahedron as isomorphic to the group A5, suggesting that these rotations permute a collection of five objects related to the solid.
  • Another participant questions the interpretation of how rotations permute the faces and suggests that arbitrary choices of five objects might not be meaningful unless they are all related to the dodecahedron.
  • A participant proposes that a set of five objects must be found such that every rotation takes one object to another or the same object, indicating the need for a group homomorphism.
  • One participant speculates about constructing a set of symmetrical objects from the edges of the dodecahedron, considering the possibility of mapping these objects under the rotations.
  • Another participant agrees with the previous speculation, suggesting that a cube can be embedded for each choice of three opposite pairs of edges, relating edges to faces of the cube.
  • Some participants express confusion about how edges of the dodecahedron correspond to faces of a cube, indicating a need for further clarification on this relationship.
Participants express various viewpoints on how to identify a meaningful set of five objects related to the dodecahedron's geometry. There is no consensus on the specific objects or the method of embedding a cube, as some participants remain uncertain about the relationships being proposed.
Participants mention various geometric features of the dodecahedron, such as faces, edges, and vertices, but there is an ongoing exploration of how these features can be systematically related to a set of five objects. The discussion includes assumptions about symmetry and the nature of the rotations, which remain unresolved.
mathwonk
imagine a regular dodecahedron, and its group of rotations. this group is "simple" of order 60, hence isomorphic to the group A5, of even permutations of 5 elements.
i.e. each face is preserved by 5 rotations, yet can be translated to 12 different faces, hence there are 60 motions in all.
can one see how the rotations of a dodecahedron do indeed permute faithfully some collection of 5 objects associated to that solid?
Note that these rotations certainly permute the 12 faces, the 20 vertices, and the 30 edges, hence also the 6 axes joining centers of opposite faces, and the 15 axes joining opposite edges, and the 10 axes joining opposite pairs of vertices, but what collection of 5 objects is permuted?
It helps to look at a picture.
I'm not exactly sure what you're asking. What do you mean when you say that "these rotations certainly permute the 12 faces?" Do you mean that given any two faces, there is some rotation (of the 60) that rotates one of the faces to the other? Couldn't we just arbitrarily choose any 5 objects related to the dodecahedron to answer your question? I guess these 5 objects should be all of the objects of that type (i.e. we wouldn't just choose any 5 corners because there are 20 corners in all).
EDIT: Originally, I guessed that we would take those 10 axes joining the 20 opposite pairs of corners, and take the axes joining midpoints of opposite axes, but all those axes share the same midpoint (the center of the dodecahedron), so that doesn't work, but perhaps there is something in the idea of pairing those 10 axes to get 5 pairs of axes, attaching some "meaningful" object to each pair, and then arguing that those 5 objects are preserved under rotations. This is assuming I understand what you're asking.
you have to find a set of 5 things such that every rotation takes one of them to another one, or the same one. i.e. such that you get a group homomorphism from the group of rotations nito the group of epormutations of the 5 objects.
for example every rotation peserving the dodecahedron sends faces to faces, so gives a permutation of the 12 faces. Indeed you could consider the pairs of opposite faces but this only represents your group in the permutation group on 6 objects.
you cannot choose a subset of the vertices because the group of all rotations will not map that subset into itself.
Dodecahedron Problem
Since the shape has 30 edges, and this number is divisable by 5, should I be aiming to construct a set of object symetrical to one another that consists of 6 edges? or is that going to send me down the garden path?
And would twelve of the rotations map one of the constructed 5 objects onto itself?
Just a stab in the dark, but I'm inclined to select 3 sets of opposite edges, where the sets of three edges map to each other with 4 basic rotations, that is two rotations around one of the six axis and two rotations around another one of the axis, and if an edge has vertices (v1,v2) it moves to like :
(v1,v2)-> (v2,v3)-> (v3,v4) -> (v4,v5)->(v5,v6), where vi does not equal vj, and (v3,v4) is an opposite edge.
Ill post later when I find out I'm probbaly wrong!
that is exactly correct! In fact if you look hard, you can see how to embed a cube for each choice of three opposite pairs of edges. such that the 6 faces of the cube correspond to the 6 edges.
I still can't see how you can imbed a cube. How does an edge correspond to the face of a cube? An interesting problem though to get me thinking about groups again.
i think the face of the cube lies right under the edge of the dodecahedron, and the edge of the dodecahedron bisects the face of the cube.
13K
