Finite amount of degree of freedom for entropy available in universe (?)
The discussion revolves around the concept of entropy in the universe, particularly in relation to the Cosmic Microwave Background radiation and the implications of gravitational effects on entropy. Participants explore the theoretical maximum entropy of the observable universe, the role of black holes, and the potential fate of the universe regarding entropy and gravitational energy.
  • Some participants propose that the Cosmic Microwave Background radiation indicates a state of thermal equilibrium, suggesting a theoretical maximum entropy for the observable universe.
  • Others argue that with gravity, a uniform distribution does not represent maximal entropy, even in thermal equilibrium.
  • There is a discussion about whether black holes represent a state of maximum gravitational entropy, with some suggesting that maximum gravitational energy may be reached once all black holes evaporate.
  • Participants question the concept of "gravitational entropy" and its implications, with some asserting that entropy is a property of whole systems rather than forces.
  • One participant speculates that the universe could stabilize into a state with a single massive black hole and a background radiation field, raising questions about the stability of such an equilibrium.
  • Concerns are raised about the universe's accelerated expansion and its impact on the potential for black holes to evaporate and the overall entropy of the universe.
Participants express multiple competing views regarding the nature of entropy in the universe, the role of black holes, and the implications of gravitational effects. The discussion remains unresolved, with no consensus on key points.
Limitations include uncertainties about the definitions of gravitational entropy and the conditions under which black holes might evaporate. The discussion also reflects varying assumptions about the universe's expansion and its effects on entropy.
_heretic
The spectrum of the Cosmic Microwave Background radiation - the flash of the Big Bang, aligns almost precisely with the shape of the Black Body radiation curve. This means that the CMB radiation came from a state that was in thermal equilibrium.
Since thermal equilibrium is a state of maximum entropy, doesn't this means that there is a theoretical maximum to the entropy of our observable universe? i.e. entropy can not (overall) continue increasing forever, it must eventually reach a maximum and stop?
Thanks in advance,
_heretic
Science news on Phys.org
With gravity, a uniform distribution is not a state of maximal entropy, even in thermal equilibrium.
For a discussion about the entropy of the observable universe, see here (pdf) for example. As the observable universe is finite, it should have a finite maximal entropy (and they give values for its current entropy). For the total universe, it depends on its size (finite <-> infinite).
Thanks for the link :)
For gravity, what would be a state of maximum entropy? Black holes?
For a low density, just very low-energetic photons probably - and black holes produce that as Hawking radiation.
Thanks again,
Would maximum gravitational energy be reached once all of the black holes evaporate, then?
"maximum gravitational energy"? Minimal absolute value of (negative) binding energy? In that case: Yes.
I apologise, I meant to say "maximum gravitational entropy." So when all of the black holes evaporate, does that represent maximum gravitational entropy?
What is "gravitational entropy"?
The entropy of the gravitational field.
What is "The entropy of the gravitational field."?
Entropy is a property of whole systems, not a property of forces.
I don't think that black holes will necessarily all evaporate. Eventually the universe could settle into a state with a single massive black hole surrounded by a background radiation field, where the temperature of the black hole and the background radiation are equal, so the black hole and radiation field are in equilibrium. Since the black hole temperature rises when the mass decreases, it's hard to figure out if this is a stable or unstable equilibrium. If the absolute value of the heat capacity of the black hole is larger than the heat capacity of the surrounding universe, then I suppose the black hole will tend to evaporate until it disappears.
I guess the fate of the universe depends on how fast it is expanding. 1 solar mass black holes have a temperature of some 60 nK according to wikipedia, which is much less than the cosmic background temperature ~2.7K, so in current conditions, black holes tend to increase in size rather than evaporate. So, it looks like black holes won't evaporate, and the maximum entropy universe seems to contain black holes. But, as the universe expands, the background temperature decreases. The question is, will the universe keep expanding past the point where background temperature is colder than all the black holes? Then the black holes will evaporate, and we are left with a, for all purposes, empty universe. Entropy will be large simply because the universe is so utterly big.
With accelerated expansion, such an equilibrium cannot exist. All radiation coming from the black hole would be lost forever.
It is accelerating already with the current, "high" energy density. Why should it stop to do so with a lower density?
I don't know, but we don't really know what is driving the expansion in the first place. It is assumed that a cosmological constant is driving the expansion, but maybe it isn't so constant.
  • · Replies 17 ·
  • · Replies 32 ·
12K
  • · Replies 21 ·
