Existence of a two variable function limit
The discussion revolves around determining the existence of the limit of the function f(x,y) = sqrt(x*y) / (x^2 - y^2) as (x,y) approaches (0,0). Participants explore various paths and substitutions to analyze the limit's behavior.
  • Participants attempt to evaluate the limit using different coordinate paths, such as y=x, y=0, and y=sqrt(x). Some express confusion about the results along these paths, particularly regarding the behavior of the denominator.
There is an ongoing exploration of the limit's existence, with some participants suggesting that the limit does not exist based on their findings along specific paths. Others raise questions about the appropriateness of certain substitutions and the implications of division by zero.
Some participants note that the function is undefined along the line y=x, which complicates the analysis. There are also discussions about the implications of substituting variables and the interpretation of results from different paths.
Jalo
In this exercice I'm asked to find out if the limif of the function f(x,y) exists.
lim (x,y)→(0,0) sqrt(x*y) / (x^2 - y^2)
I've tried to approach it from different coordinates (y=x, y=0, x=0, y=sqrt(x),...) but I didn't found any limit...
I also tried to prove it didn't exist with the iteration property without luck...
Any hint would be highly appreciated.
Thanks.
Thanks.
Try along lines like ##y=mx## for various ##m##.
Jalo said:
In this exercise I'm asked to find out if the limit of the function f(x,y) exists.
Thanks.
Along x=0 and y=0, the limit definitely exists.
Along the line y=x, what is true of the denominator, x-y2 ?
See what happens along the curve, x=y3.
If I substitute y for x I'll get
sqrt(y*y) / (y² - y²) = y / (y² - y²) = 1 / (y-y)
Which is 1/0, an indetermination. I don't get a physical value therefore I can't conclude nothing from this limit.. ( I think? correct me if I'm wrong)
As to x=y³
sqrt(y³*y) / ( (y³)² - y²) = y² / (y⁶ - y²) = 1 / (y⁴ - 1) = -1
I decided to compare it to
x=4*y³
sqrt(4*y³*y) / ( (4*y³)² - y²) = 2*y² / (16*y⁶ - y²) = 2 / (16*y⁴ - 1) = -2
I can now conclude that the limit doesn't exist.
Could someone just comment on the result of the x=y substitution? Have I done it incorrectly?
Thank you very much.
D.
EDIT: Also, can I substitute x for y+n, where n is some random number belonging |R² ?
No, "1/0" is NOT an "indetermination" (better English would be "indeterminate"). "0/0" is an indeterminate. Getting "1/0" is itself enough to conclude that the limit does not exist.
As to x=y³
x=4*y³
D.
You're right in that you have division by zero. You have |y|/0 all along the line y=x. But, that's not an indeterminate form. When taking the limit as y→0 you get a result of +∞.
As to x=y³
So, there you have it. The limit is +∞ along one path, and -1 along another.
x=4*y³
D.
For x = y+n, for n a non-zero number, that does not pass through the origin.
If you literally mean x=y+(a, b), that's not any defined operation as far as I know.
You originally implied that the limit doesn't exist along x=0 and y=0. Those limits do exist, and they are zero. So, your original paths, along y=x, and y=0 or x=0, are enoough to show that the limit does not exist, but using a path such as x = ay3 or y = ax3 does give nice results.
Others have commented about your calculation of the x=y substitution. But I would comment about its appropriateness. None of the points on y=x are in the domain of the function so it doesn't make sense to even consider that path when studying the limit in question. But, as you have seen, other paths will do.
I would disagree with that. See my post #7.
Yes, of course you are correct !
Unfortunately, I had a typo in post #3, but that should have said that along the line y=x, what does the denominator x2 - y2 become? Of course, the answer is that the denominator is zero, so that the overall expression is undefined along y = x.
