Quick domain of function question: Why do you have 2 cases for this function?
  • Thread starter Thread starter nukeman
    Domain Function
The discussion revolves around understanding the domain of functions, particularly focusing on cases where the expressions involve square roots and rational functions. Participants are exploring why certain conditions lead to multiple cases in determining the domain.
  • Participants are attempting to understand why two cases are considered for the function involving a square root, questioning the conditions under which the numerator and denominator must be either both positive or both negative.
  • There is exploration of the domain of rational functions, with participants discussing the implications of the denominator being zero and the conditions for continuity.
  • Some participants express confusion regarding the correct interpretation of domain restrictions when no radical is present.
The discussion is ongoing, with participants providing insights into the reasoning behind domain restrictions. Some have offered clarifications regarding the conditions for rational functions and the implications of square roots, while others are still seeking clarity on specific examples and general rules.
Participants are navigating the complexities of function domains, particularly in the context of homework constraints that may limit their exploration of these concepts. There is an emphasis on understanding the relationship between the numerator and denominator in various function types.
nukeman
This question here. Can someone please tell me why we have 2 cases to consider.
http://archives.math.utk.edu/visual.calculus/0/domain.1/8.html
I don't understand why it says we have 2 cases to consider.
8 x - 4 > 0 and x - 3 > 0.
8 x - 4 < 0 and x - 3 < 0.
why is one greater than and less than?
The expression under the square root can not be negative. Therefore the sign of both the numerator and denominator have to be same - either positive or negative. ehild
ahhhg. I don't fully understand.
Well, as ehild said, the total value of the function under the radical cannot be negative in order to produce a real value. Therefore, both the numerator and the denominator under the radical must both be either positive or negative to result in a positive under the radical. The easiest way to solve [itex]\frac{8x-4}{x-3} = 0[/itex] is to solve the numerator such as this:
8x-4 ≥ 0, if x-3 > 0 and 8x-4 ≤ 0, if x-3 < 0
For simplicity, use something like this:
8x-4 = A
x-3 = B
Then solve:
A ≥ 0
= x ≥ 1/2
B > 0
= x > 3
Then the negative solution,
A ≤ 0
= x ≤ 1/2
B < 0
= x < 3
Putting the first two parts and the second sets together, you get the cases for the function:
A ≥ 1/2 if B > 3,
A ≤ 1/2 if B < 3
Hope this helps you!
ahhh GOT it!
how about this: (x^2 - 1) / (x + 1)
would it not just be x must be greater than -1 ??
why is the answer (-infinity, -1) (-1, infinity)
For a standard rational function, it is continuous except when the denominator is equal to 0. Therefore, you solve x + 1 = 0, and x = -1, giving you the only place that the denominator will be zero. However, if it was a radical like the other problem, the solution would be x > -1, since at all other places there will be a negative under the radical.
nukeman said:
ahhh GOT it!
That's not a complete question.
What is it that you want to do with (x2-1)/(x+1) ?
so when there is NO radical... all we would do is evaluate the denominator and its always just must not equal to 0 ?
I don't understand, because let's take this question then.
1/(x + 5)
I would just go:
x + 5 > 0
x > -5
But from you are saying, that's wrong!
I should then just go x CANNOT equal 5, it would be (-∞, -5)(-5, ∞) ?
Correct, as long as there isn't something else going on with the function that somehow restricts values. That is what happened with the rational function under the square root; since there is not a real solution for a negative under a square root, it it not within the domain. Similar things could happen if there was something such as a logarithm somewhere in the function. As long as there are nothing except integer polynomials in the numerator and denominator, the only restrictions of the domain are values that result in the denominator being equal to 0.
And yes, the solution to the domain of [itex]\frac{1}{x+5}[/itex] would be (-∞,-5), (-5,∞).
  • · Replies 27 ·
