Calculating variance of a single statistic from different collections of data
The discussion revolves around the statistical analysis of measurements taken from a machine designed to calculate the bounce rate of different "magical" balls. Participants explore how to relate accuracy and precision across different datasets, the implications of periodic motion on statistical analysis, and the creation of a normal distribution from these readings. The conversation touches on concepts of variance, error, and the assumptions made about the measuring device.
  • Some participants question whether the periodic nature of the bounce affects the statistical analysis, comparing it to measurements taken from different weights.
  • There is a discussion about the machine's measurement process, with some suggesting that the number of measurements could influence the precision of the rate calculated.
  • One participant asks how to create a single normal distribution from readings of different balls, while another questions the rationale behind combining these readings.
  • Concerns are raised about the assumptions regarding the machine's precision and whether it varies with the rate of bounce.
  • Participants discuss the implications of assuming the variance of errors does not depend on the magnitude of the measurement, and how this affects the calculation of mean and variance for a normal distribution of errors.
  • There is mention of the potential for large percentage errors depending on the nature of the measurements, suggesting that the context of the measurements is crucial for accurate analysis.
Participants express differing views on the impact of the machine's characteristics on the statistical analysis, and whether the periodic nature of the measurements should be considered. There is no consensus on the best approach to combine readings or the assumptions about error variance.
Participants highlight the need for actual data or knowledge of the physics involved to accurately assess the variability of error in measurements. The discussion also reflects uncertainty regarding the assumptions made about the measuring device and its impact on the analysis.
This discussion may be useful for those interested in statistical analysis, measurement theory, and the implications of error in experimental data, particularly in contexts involving periodic phenomena.
spaceWatch
Let's assume there's a magical ball that bounces once every .5 seconds, and that there was a specific machine designed to calculate the rate of the ball's bounce (with error). After performing numerous readings of the ball's bounce using this machine, you have a collection of values describing the rate at which the ball bounces for this particular ball.
Now, say you have another magical ball that bounces once every .25 seconds, and used the same machine from before to read the rate at which this other ball bounces. After getting some data, you now have data on the bounce-per-.5-second ball and the bounce-per-.25-second ball.
Question: How would one be able to relate the accuracy and precision of this machine between the readings of the two balls?
Question from different perspective: Could you relate the standard deviation from readings from the first ball to readings from the second?
Question from another perspective: Would it be possible, after collecting readings from the first ball and the second ball, to estimate the readings present in a third magic ball which bounced at a different rate?
Question from yet another perspective: How would you analyze the machine's precision off a collection of balls with different bounce frequencies?
Any feedback would be greatly appreciated. Preferably, if this type of statistical analysis exists, I'd like to know the name. I'm having immense trouble finding this type of analysis using google.
_
It will be important to clarify whether the periodic motion in this problem really has any impact on the statistical analysis. In other words, is there any difference in analyzing these measurements vs analyzing two sets of measurements with a scale, one set on a 0.5 kg mass and the other on a 0.25 kg mass?
You say the machine measures the "rate" at which the ball bounces and not something like the times when the ball lands. If I imagine a reall machine to do this job it would have an "integration time". Over a certain time interval, it would detect the ball interrupting light to a photo diode. It would record the time's when this happened. Then it would produce a rate based on average time between these events, using all the events it recorded in the integration time interval. If it measured a ball bouncing every 0.25 seconds, it would have more measurements to average than with the slower ball. So the final output of the measurement as a rate might have different precision for balls bouncing at different rates.
Are we to assume the machine is just a "black box" that has the same precison regardless of the rate of bounce of the balls?
On an added note, how would you create a single normal distribution of the machine's readings when the machine reads different balls?
EDIT: And yes, it's best to assume the machine as a black box with the same precision no matter how long it's been looking at a ball.
Why would you want to combine readings from both balls into one distribution? Did you mean you want a single normal distribution of the errors the machine makes?
If this is a real life problem, it would be best if you described that problem rather than attempt to abstract the mathematics from it on your own. If this is hypothetical problem, then we can discuss it that way. If the machine is being treated as a black box, it would simpler to forget about the bouncing balls and just think about a machine that measures weights, or heights etc.
The overall goal is to create a normal distribution which can be used to visually describe the accuracy and precision of something, when the 'something' is used on a multitude of different objects.
Granted, the ball-rate-measuring-machine was an example. One could use anything that can measure anything.
Assume the variance of the errors of the device doesn't depend on the true magnitude of what it is measuring. ( For example, assume the variability of the error a scale makes doesn't increase with the weight of the thing measured - as if would if the scale had a constant variabiliy in its percentage error rather than a constant variability in error)
Assume that the mean error of the device is 0.
Given that you know the correct value of the thing being measured, you can compute the error made on each measurement. You can combine all these observations of errors into one data set and estimate the mean and variance of the normal distribution that fits it. Is that what you want?
Percentage error, in some cases, could be huge. If said scale was inaccurate enough to measure an object whose weight is similar to its error, percent error could be over 1.
I suppose it would depend on the things being weighed. If the error depended on the object being measured, it would be percentage error. If not, it would be a flat plus-or-minus. Both normal distributions would have a high-point at 0. I suppose one would need to look at actual results of said hypothetical data in order to look at how best to group it.
Thanks!
Yes, you'd have to look at actual data or know the physics involved to determine if the variability of the error depends on the magnitude of the thing being measued. So the problem also includes estimating a formula for this dependence.
  • · Replies 64 ·
  • · Replies 24 ·
  • · Replies 17 ·
  • · Replies 48 ·
