Linear Algebra: Span, Linear Independence Proof
The problem involves proving the linear independence of a set of vectors \( v_1, v_2, v_3, \ldots, v_n \) under specific conditions regarding their spans. The original poster presents a proof attempt using mathematical induction and references the definitions of linear independence and span.
  • The original poster attempts to use induction to prove linear independence, starting with the base case and moving to the inductive step. They express uncertainty about showing that \( v_{n+1} \) is not the zero vector and question their understanding of the proof process.
Participants are actively engaging with the proof attempt, providing feedback and guidance. One participant suggests a clarification regarding the zero vector's presence in spans, which helps the original poster refine their argument. There is a sense of progress, but no explicit consensus on the proof's completeness is reached.
The discussion highlights the original poster's beginner status in proof writing and the challenges they face in understanding the implications of linear independence and spans. There is an acknowledgment of the assumptions required for the proof, particularly regarding the nature of the zero vector.
miglo
Suppose v_1,v_2,v_3,...v_n are vectors such that v_1 does not equal the zero vector
and v_2 not in span{v_1}, v_3 not in span{v_1,v_2}, v_n not in span{v_1,v_2,...v_(n-1)}
show that v_1,v_2,v_3,...,V_n are linearly independent.
linear independence, span
he gave us a hint, which was to use induction
heres what i have so far
for the base case n=1
v_1 does not equal 0
so for cv_1=0, c must equal 0 making v_1 linearly independent
then assume v_n is linearly independent to show v_(n+1) is linearly independent
since v_n is linearly independent, then v_1,v_2,v_3,v_(n-1) are all linearly independent as well, my books states this as a remark to linear independence so i assume i can use it
and v_(n+1) not in span{v_1,...v_n}
therefore c_1v_1+c_2v_2+...+c_nv_n+c_(n+1)v_(n+1)=0 if either
c_(n+1)v_(n+1)=-c_1v_1-c_2v_2-...-c_nv_n
or c_(n+1)v_(n+1)=0
the former isn't true since its not in the span of all the vectors before it so then the latter must hold true
this is where i started doubting myself because then i would have to show that v_(n+1) is not zero and I am unsure on how to do that, also I am a beginner with proofs so I am not even sure if I am doing this correctly using induction
thanks in advance
or c_(n+1)v_(n+1)=0
thanks in advance
You are really close. You can say v_(n+1) is not the zero vector. The zero vector is in the span of any set of vectors. Try and restate your argument knowing that.
so can i just say since the zero vector is in the span of any set of vectors and v_(n+1) is not in the span of all the vectors before it then v_(n+1) is not the zero vector??
if that's correct then c_(n+1) must equal zero thus showing that all the vectors are linearly independent
Yes, that's pretty much it. If c_(n+1) is nonzero then v_(n+1) is in the span, contradiction. If c_(n+1) is zero then it shows they are linearly independent. Well done. You are better at proofs than you thought.
cool thanks!
  • · Replies 45 ·
