How does changing the metric on a manifold affect the shape of the manifold?
  • Context: Graduate
  • Thread starter Thread starter meldraft
    Manifold Metric Shape
The discussion revolves around the effects of changing the metric on a manifold, particularly in the context of geometric flows like the Ricci flow. Participants explore the implications of metric changes on the shape of manifolds, focusing on surfaces and the mathematical underpinnings of these concepts.
  • One participant questions how a geometric flow, which alters the metric tensor, affects the shape of a manifold, suggesting that changing the measure of distance should not yield a different shape.
  • Another participant provides an example of a metric on a 2-sphere and discusses how varying the radius corresponds to changing the embedding of the manifold in R³.
  • A third participant mentions that a topological manifold may lack a defined metric, and discusses conditions under which a metric tensor can be constructed, emphasizing the importance of local geometrization.
  • Some participants express uncertainty about the implications of deforming a metric in a Riemannian manifold and how this relates to the manifold's embedding in higher-dimensional spaces.
  • There is a discussion about the Ricci flow equation and the challenges of incorporating a time parameter into the parametrization of a surface.
  • One participant notes that in intrinsic geometry, the concept of "shape" is not meaningful without considering how a manifold is embedded in R^n, highlighting the distinction between metric information and extrinsic curvature.
  • Another participant suggests that the Ricci flow allows for the study of smooth deformations of manifolds, while also addressing the relationship between the time parameter and the geometry of the manifold.
Participants express differing views on the relationship between metric changes and the concept of shape, with no consensus reached on how these concepts interact. The discussion remains unresolved regarding the implications of metric deformation and the proper incorporation of time in the Ricci flow.
Participants mention various conditions for geometrization and the challenges associated with defining metrics on manifolds, indicating that there are unresolved assumptions and dependencies in the discussion.
meldraft
Hi all,
I am trying to understand geometric flows, and in particular the Ricci flow. I understand how to calculate the metric tensor from the parametrization of a surface, but I am facing a problems in the concept phase.
A metric tensor's purpose is to provide a coordinate invariant expression for the shape (in the form of distance) of an object, i.e. a surface. A geometric flow changes the metric tensor. Therefore, the shape of the manifold will change, obviously for any coordinate system.
So, what exactly is the product of a geometric flow? Let's stick to surfaces for now, so is it the original surface endowed with a new measure of distance? The way I understand it is that since the shape of the original surface is invariant, changing how we measure distance on the surface shouldn't yield a different shape. So does this mean that by defining a new metric for a surface we get a different surface?
If so, I am missing something here because I can't understand how defining a new measure of distance for an object creates a new, different object.
I would be grateful if someone could showcase or guide me through applying a geometric flow for a simple shape, i.e. an ellipsoid.
My knowledge of the Ricci flow is extremely minimal, and basically consists of this one example: You can put a metric on a 2-sphere by embedding it has the standard sphere of radius r in R³. In spherical coordinate (θ,[itex]\phi[/itex]), the metric is then r²(dθdθ + sin² d[itex]\phi[/itex]d[itex]\phi[/itex]). So we see that varying the r parameter in there corresponds to varying the radius of the embedded sphere. As r-->0, the sphere degenerates into a point.
Conversely, any riemannian manifold can be embedded isometrically into some R^n (Nash's embedding theorem), so given any riemannian manifold (M,g), varying g can be seen as varying the embedding of M in R^n.
a topological manifold may not have a metric yet defined on it. but you can construct a metric tensor field on the manifold if the manifold satisfies some (uncertain to me) geometrisation conditions (i think hausdorff compact or normalisable or something like that).
the main point of the ricci flow is that if the manifold is locally geometrisable, it is globally geometrisable. that is, from a compatible family of local metrics, there is a single globally defined metric equivalent to it. this is under a suitable limit on a family of metrics that describe the diffeomorphism equivalence class. so by way of this equivalence, you see the diffeomorphism dually either as deforming the manifold and its attached tensor field, or as a fixed manifold conformally transforming the metric itself.
the main problem is that you want some well defined way of defining geometrisation locally and them some way of bulding this geometrisation globally so that we can identify it with a product of canonical (Lie group) manifolds under the ricci flow. the obstruction to this is failing to be geometrisable somewhere - hense the known categorisation of type singularities.
sorry I'm not sure if that helps or is even completely accurate.
meldraft said:
Hi all,
Maybe you need to get a better understanding of what deforming a metric in a Riemannian manifold implies as opposed to what you mean by just "defining a new measure of distance".
There are some actually well versed people around here, hopefully they can help you with this.
This helps a lot, thank you.
You are correct, this is essentially the core of my question, what deforming a metric in a Riemannian manifold actually means. If I understand quasar's explanation correctly, it produces a different embedding of M in R^n, therefore a shape that looks different but can at any time be reverted to the original manifold using the 'current' metric?
Also a practical issue, the Ricci flow equation is:
[tex]\partial_t g_{ij}=-2R_{ij}[/tex]
I have calculated the Ricci tensor, but I am having trouble with the 'time' parameter. The parametrization of a 3D surface needs two parameters, let's say u,v. How do I apply the time differentiation? Do I need to express u,v as functions of 't'? As far as I know it is possible to express a 3D curve using just one parameter, but I do not know how to express a surface in that form.
In purely intrinsic geometry, the "shape" of a manifold is meaningless. What we mean by "shape" has a lot more to do with how a manifold is embedded into some R^n. For example, a flat sheet of paper has many different isometric embeddings into R^3, which you can achieve by all the ways you might imagine bending, crumpling, etc., a sheet of paper. Hence the metric information alone is not enough to constrain the shape information; the "shape" is really the collection of all the extrinsic curvatures.
You introduce "time" as a third parameter, i.e.
[tex]g_{ij} = g_{ij}(u, v; t)[/tex]
For example, you might write a sphere as
[tex]ds^2 = a(t)^2 (d\theta^2 + \sin^2 \theta \; d\phi^2)[/tex]
Thank you, this helps me immensely! I'll try it out tomorrow and see if I can get it to work :biggrin:
Another, slightly different, way of writing the Ricci flow equation would be:
\begin{equation}
\partial_\beta \, g_{i j} (\beta) = - 2 R_{i j} (\beta) \, ,
\end{equation}
with the following property:
\begin{equation}
g_{i j} (0) = g_{i j} \, .
\end{equation}
gij would stand for the `unaffected' metric in the sense that, when you consider your additional parameter β equal to zero, you recover your `initial' metric (or initial geometry).
So β should not in general be related with the time parameter of your coordinate system. In other words, for any given β, you can choose a different coordinate system that won't affect the geometry of your manifold. However, a different β gives you a different geometry.
As far as I know/understand, the Ricci flow provides a way of studying smooth deformations of manifolds.
Hmmmm. I am struggling quite a bit to wrap my mind around how to properly insert 'time' into the equation. Let's assume that I have a metric:
[tex]g_{ij}=\left(\begin{array}{cc}g_{11}(u,v)&g_{12}(u,v)\\g_{21}(u,v)&g_{22}(u,v)\end{array}\right)[/tex]
I could parametrize it for time like:
[tex]g_{ij}(t)=(1-2t) \left(\begin{array}{cc}g_{11}(u,v)&g_{12}(u,v)\\g_{21}(u,v)&g_{22}(u,v)\end{array}\right)[/tex]
so that the time integrations and differentiations (for the Ricci tensor as a function of [itex]g_{ij}(t)[/itex]) become trivial. I've seen this parameterization in a few papers. However, by doing this aren't I imposing a pre-determined way that the manifold will deform? It seems in this sense that whether the manifold becomes a 3-sphere or not depends intensely on choosing the proper parametrization. Perelman (I can't really keep up with the details of the proof yet) however proved that this is always possible for a closed smooth 3-manifold, so what am I missing? Does the proof imply/state that convergence depends on proper parametrization? What would the parameterization be for an arbitrary manifold then?
Sorry if I'm confusing a few concepts, but differential topology is still quite new to me :-p
  • · Replies 16 ·
  • · Replies 22 ·
  • · Replies 17 ·
