Physics - work done by a spring
The discussion revolves around a physics problem involving a block colliding with a spring, focusing on calculating the work done by the spring and the work done by friction. The subject area includes concepts of energy, work, and friction in mechanics.
  • Participants discuss the formula for calculating the work done by the spring and question the sign of the result. There is also consideration of how to incorporate the work done by friction into the overall energy calculations.
Some participants have reached a consensus on the values for work done by the spring and friction, while others are exploring the implications of the signs used in their calculations. The discussion reflects a mix of agreement and differing interpretations regarding the correct approach to the problem.
Participants are navigating the nuances of sign conventions in work calculations, particularly in relation to energy transfer and friction. There is mention of a program's feedback on their answers, which influences their reasoning.
Felix83
A moving 4.90 kg block collides with a horizontal spring whose spring constant is 437 N/m.
The block compresses the spring a maximum distance of 6.50 cm from its rest position. The coefficient of kinetic friction between the block and the horizontal surface is 0.190. What is the work done by the spring in bringing the block to rest?
The Part after that is to find the work done by friction, which I got correct. The last part is to find the initial velocity of the block, I could just add the work done by friction and the spring and then solve for v with the KE formula.
However, I can't seem to find the work done by the spring to bring the block to rest. Wouldn't you just use the formula W=(1/2)kx^2 ? I used that and got 0.923 J, which the program says is incorrect.
Obviously there has to be a minus in the result,so it should be -0.923J.Indeed,to me,that seems to be the answer,the dork done by the elastic force acting on the body is - the elastic potential energy...
Weird,maybe something is evading my senses,but,for now,i'd say that's the correct result.
Daniel.
Appears that {Work Done By Spring}=(-0.923 J), {Work Done by Friction}=(-0.594 J), and {Initial Velocity}=(+0.787 m/sec) should be correct.
yea those are the numbers i got too, but i put the friction in as positive and it said correct so i figured since the spring was pushing in the same direction it would be positive too. but these problems are dumb sometimes so i tried negative 0.923 and of course that was right.
  • · Replies 58 ·
