Velocity, Work, and Energy of a Falling Meteor
The discussion focuses on the physics of a meteor falling from a height of 700 km with an initial speed of 94.0 m/s. The correct approach to determine the speed just before impact involves using conservation of energy principles rather than constant acceleration equations, due to the varying gravitational force at such heights. The mass of the meteor is 545 kg, and the work done by the sand to stop the meteor can be calculated using the work-energy principle. The average force exerted by the sand and the thermal energy produced during the impact are also key calculations derived from the work done.
  • Understanding of conservation of energy principles in physics
  • Knowledge of gravitational force variations with altitude
  • Familiarity with kinetic energy and work-energy equations
  • Basic skills in solving quadratic equations
  • Study the conservation of energy in gravitational fields
  • Learn about variable acceleration and its implications in physics problems
  • Explore the work-energy theorem and its applications
  • Investigate the effects of impact forces and energy dissipation in collisions
Students studying physics, particularly those focusing on mechanics, as well as educators looking for practical examples of energy conservation and force calculations in real-world scenarios.
RoosterCancer
A meteor has a speed of 94.0 m/s when 700 km above the Earth. It is falling vertically (ignore air resistance) and strikes a bed of sand in which it is brought to rest in 3.03 m.
a) What is its speed just before striking the sand?
b) How much work does the sand do to stop the meteor (mass = 545 kg)?
c) What is the average force exerted by the sand on the meteor?
(d) How much thermal energy is produced?
KE=0.5*m*v^2
Work=force*distance
vf^2=vi^2+2a(xf-xi)
I'm having trouble with the first part, and it looks like the answer for it is required for the other parts.
I tried using vf^2=vi^2+2a(xf-xi) to find the velocity for part a. Plugging in the numbers gives vf^2=(94 m/s)^2+2(9.8 m/s^2)(700000m). This results in vf=3705.244, however this is not correct. What am I doing wrong?
Note that the meteor is falling from significantly higher than ground level. This means that the force of gravity will not be constant when it is falling. The equation you are attempting to use, [itex]v_f^2 = v_i^2 + 2A \Delta x,[/itex] is meant to be applied to problems where the acceleration will be constant. I would think this is your mistake. I would suggest trying part a as a conservation of energy problem. Keep in mind that the potential energy of gravity will not be mgh for the same reasons I pointed out above.
  • · Replies 34 ·
