Finding the area/volume for a transformed parallelogram/parallelepiped?
  • Thread starter Thread starter richashah
This discussion focuses on calculating the area and volume of transformed geometric shapes, specifically a parallelogram and a parallelepiped, under given linear transformations. For the parallelogram defined by the corners (0,0), (1,-1), and (4,7) with transformation T(x) = (3x + 4y, 4x + 5y), the area is determined using the determinant of the transformation matrix and the cross product of the spanning vectors. The user initially calculated the area as 3, but the correct area is 11, indicating an arithmetic error. For the parallelepiped defined by the corners (1,1,1), (1,1,2), (1,2,1), and (2,1,1) with transformation T(x) = (3y, -4x, 5z), the user expressed confusion regarding the volume calculation.
  • Understanding of linear transformations in R^2 and R^3
  • Knowledge of vector cross products and dot products
  • Familiarity with determinant calculations of transformation matrices
  • Concept of geometric properties of parallelograms and parallelepipeds
  • Review the calculation of determinants for 2x2 and 3x3 matrices
  • Study the properties of vector cross products in geometric contexts
  • Learn about the implications of linear transformations on area and volume
  • Practice solving similar problems involving transformations of geometric shapes
Students studying linear algebra, particularly those focusing on geometric transformations, as well as educators looking for examples of area and volume calculations in transformed shapes.
richashah
for the following, find (a) the image of the indicated set under the given linear transformation and (b) the area or volume of the image
question 1: P is the paralellogram in R^2 with corner (0,0) spanned by (1,-1) and (4,7);
It undergoes the transformation T(x) = (3x + 4y, 4x + 5y)
question 2: P is the parallelepiped with corner (1,1,1) spanned by (1,1,2), (1,2,1), and (2,1,1). T(x) = (3y, -4x, 5z)
I know the area of a parallelogram = ||a x b|| (cross product between vectors a and b)
The volume of a parallelepipid = ||a x b|| . c (cross product of vectors a & b. Then the dot product is used between that answer and vector c to obtain volume)
The area of a transformed parallelogram = |det(transformation matrix)|*(area of parallelogram)
The volume of a transformed parallelepiped = |det(transformation matrix)|*(volume of parallelepipid)
for question 1, I have the transformation points as (0,0) (-1,-1) and (-16,-19). For the area, I took the cross product of vectors a and b (vector a = (-1,-1) vector b = (-16,-19)) and got 3. I got the determinant equals 1. So i got the area to be 3, but the answer key says it is 11.
For question 2, I'm just completely confused to be quite honest.
You need to show what you did. For (a) Show how you got the area of the of the parallelogram and the determinant of the transformation. That's all you need to calculate the new area. I think you have arithmetic mistakes.
9K
10K
30K
