Fpt problem in quadratic residues
  • Context: Graduate
  • Thread starter Thread starter smslca
    Quadratic
The discussion centers on the quadratic residue problem (QRP) and its classification as NP-complete when considering a solution for x under a limit c. It is established that while the problem is fixed-parameter tractable (FPT) with c as a parameter, it does not imply that large values of c allow for a solution without factorization. The complexity of QRP remains uncertain, as it is not definitively proven whether it is NP-hard, particularly when the parameter c is introduced as an upper bound. Factorization is noted as a comparative method that allows QRP to be solved in polynomial time if the modulus is known.
  • Understanding of NP-completeness and computational complexity theory
  • Familiarity with fixed-parameter tractability (FPT) concepts
  • Knowledge of quadratic residues and congruences
  • Basic principles of number theory and modular arithmetic
  • Research "NP-completeness in computational problems" for deeper insights
  • Explore "fixed-parameter tractability" and its implications in algorithm design
  • Study "quadratic residues and their applications in cryptography"
  • Investigate "factorization methods in number theory" for solving congruences
This discussion is beneficial for computer scientists, mathematicians, and cryptographers interested in computational complexity, particularly those working with quadratic residues and their implications in algorithm efficiency.
smslca
In wikipedia source: http://en.wikipedia.org/wiki/Quadratic_residue
under "composite modulus" section
I found the line
"On the other hand, if we want to know if there is a solution for x less than some given limit c, this problem is NP-complete;however, this is a fixed-parameter tractable problem, where c is the parameter."
what does it mean by "given limit c , and fixed parameter tractable with c as parameter". Does this mean regardless of large values are given for c as a limit , we can solve the quadratic congruence without knowing the factorization? or does it has any other meaning?
what is the limit of c such that we cannot solve quadratic congruence using fpt
If i am wrong or obscure in my question, please notify me.
I found the line
It simply means, that the problem is dependent of (a fixed parameter) ##c## and the module ##n##. This means there are basically two input parameters in which runtime can be expressed.
No. It means: We do not know, whether the quadratic residue problem (QRP) is NP-hard or not. But it is NP-hard if we introduce the parameter ##c## as the upper bound of a possible solution into the problem. This indicates that QRP is indeed NP-hard even though we have no formal proof.
... or does it has any other meaning?
Factorization is only meant as a comparison here. And of course, if the module is factorized, then QRP can be solved in P.
  • · Replies 23 ·
