Need help designing a 'trip wire' type circuit.
The discussion revolves around designing a trip wire type circuit for an automatic shut off oven system that integrates smoke detection. Participants explore various circuit designs, focusing on how to light an LED when a connection is broken or a switch is turned off, while considering power efficiency and alternative sensing methods.
  • One participant describes the basic operation of a smoke detector using ionization and proposes a simplified circuit using a switch to light an LED.
  • Another participant suggests adjusting the resistor value based on an equation to ensure the LED lights up when the switch is open, but raises concerns about the need for minimal current through the trip wire.
  • A different participant proposes using a Darlington NPN transistor to lower the current on the trip wire, noting the importance of the base resistor value.
  • A participant shares their successful implementation of a circuit using two transistors to achieve the desired LED lighting with minimal current.
  • Another participant introduces the idea of using photoresistors to detect smoke by blocking a laser beam, suggesting a modification to the circuit design to incorporate this method.
Participants express various approaches to the circuit design, with some agreeing on the use of transistors for current management, while others propose alternative methods such as photoresistors. The discussion remains unresolved regarding the optimal design and implementation of the circuit.
Participants mention specific current requirements and configurations, but there are limitations in the details provided about the overall circuit design and the interaction between components. The discussion does not resolve the best approach to integrating photoresistors or the exact specifications needed for the circuit.
fabiobollinge
My first-year engineering group is designing an automatic shut off oven system. We will integrate smoke detector systems inside the oven. Details about that don't matter.
Smoke detectors work on a trip wire type alarm. Alpha particles are emitted from a small source of Americium, the alpha particles ionize the air and complete a circuit. When smoke enters the system, the ionization doesn't occur and the circuit is broken and the alarm is triggered.
We will be using just the ionization system, but not the built in circuit with the smoke detector, because we need to incorporate it into a larger system, and modifying the existing circuitry would be almost impossible.
Disregard the ionization system and replace it with a simple switch - on or off. And replace the entire alarm function with lighting a simple LED. We can modify the circuit from there, I just need a circuit, preferably a schematic too, that will light an LED once a connection is broken, or a switch is turned off.
Thank you for taking the time to read this!
Look up an LED, adjust the R according to the equation given. When the switch open, LED will light up.
This works excellently, however the only way for it to work excellently is to allow a large current constantly through the trip wire. And for my project the current through the trip wire should be minimal, since it will be powered on for hours at a time, and it could also be battery powered!
If you have a solution, let me know!
Next version will cost you a hamburger!
I don't know what current you require, if the current is high, you might want to consider a Darlington NPN to lower the current on the trip wire. The Base resistor can be half the [itex]\beta[/itex] times higher than the R.
Thanks! I used that idea, but I used two transistors! I got away with having a 1M resistor on the switch closed circuit, then that current is enough to just barely open the first transistor, but the small current from that is enough to nearly fully open the second transistor, lighting the LED.
Thanks for your help!
Hey again! So I tried working this into a larger circuit. But my team is going to try to use photoresistors, so when smoke blocks a laser beam, the resistance goes up, and that acts as opening the switch.
Here's the circuit I made using help from above (posts above this one ;) ). The idea is when left left most switch is opened, current is redirected the the first LED (LEDs are circles here), then the second switch opens (middle right) and turns on the second LED, and when the third switch opens (top right) the third LED goes on, and a transistor is opened, completely an exterior circuit (represented by the LED on the far right).
http://imageshack.us/a/img801/9838/oven20triggers.jpg
FYI, the max current for the LEDs is 20mA, and current source is a 9V battery.
The simulator I used was this one: http://www.falstad.com/circuit/
Now I would like to replace the switches with a system dependent on photoresistors, so when resistance is max, it acts an open switch, and vice versa.
Thank you
  • · Replies 19 ·
9K
  • · Replies 23 ·
  • · Replies 51 ·
  • · Replies 22 ·
