Modern Physics Qs - Time Dilation & Relativity
The discussion revolves around time dilation and relativity, specifically exploring scenarios involving three triplets traveling in spaceships at different speeds and durations. Participants analyze how time is perceived differently for the triplets compared to observers on Earth, leading to questions about the implications of their journeys on their ages and return times.
  • Participants attempt to calculate the return years and ages of the triplets based on given speeds and travel times, questioning the correctness of their calculations and the relationship between Parts A and B of the problem.
The discussion is ongoing with participants sharing their calculations and questioning the consistency of their results. Some have noted that the answers for Parts A and B appear to be different, leading to further exploration of the assumptions and interpretations of the problem.
Participants express confusion regarding the arrangement of data in Parts A and B, which may have contributed to misunderstandings. There is also mention of external sources that propose different answers, adding to the complexity of the discussion.
omer10000
Q1. Time Dilation Question
Three identical triplets leave Earth when they reach the age of 21, in the year 2121. Each triplet goes on a spaceship journey that takes T years, as measured by a clock in each spaceship. During the journey they travel at a constant speed v, as measured on earth, except during the relatively short acceleration phases of their journey. (Triplets occur when three babies are born together.)
Part A)
The triplets return to Earth in different years according to people who stay on Earth. Rank the triplets on the basis of the year on Earth when they return from their journey. That is, work out the year when each triplet returns, and then rank the triplets according to the largest return year to the smallest return year.
A- T= 20 years, v=0.4
B- T= 10 years, v=0.8
C- T= 10 years, v=0.4
Part B)
Calculate the age of each triplet when they return from their journey. Rank the triplets on the basis of their return age.
A- T= 10 years, v=0.4
B- T= 20 years, v=0.4
C- T= 10 years, v=0.8
Δt' = x*b where b = √(1-(v/c)^2) → x = (Δt')/√(1-(v/c)^2) => PART A
Part A - Solving for x: A = 22 yrs...B = 17 yrs...C = 11
Is this correct? I don't think so; answer might be: B A C. How is this possible?
Part B
Shouldn't the answer be same as Part A? Apparently it may be: C A B. Why?
Q2. Relativity
1. Homework Statement
A spaceship passes Earth moving at 0.80c. The spaceship then passes the Moon. How much time, according to the ship's clock, elapses between the time a person looking out the ship's window sees Earth pass by and when the Moon passes by. The Earth-Moon distance is approximately 3.84*10^8m
Δt = Δx/v
Δt'=Δt*√(1-(v/c)^2)
Δt = Δx/v = (3.84*10^8m)/((3.0*10^8)*0.80c) = 1.6s
Δt'=Δt*√(1-(v/c)^2)=1.6*√(1-0.8^2)=0.96s
|^| Is this in reference to person in spaceship?
Thanks
Why do you think your answer is not correct?
Part B
You are basically told the answer to this one. (You are told their clock readings during the trip.)
Δt is the time as measured by Earth clocks; Δt' is the time measured on the ship, which is what you want.
Doc Al said:
Why do you think your answer is not correct?You are basically told the answer to this one. (You are told their clock readings during the trip.)
It is odd that the answer is uniformly fitting the given options; ie. A B C options are answered CORRECTLY as A B C
I knew the answer to this but just wanted to double check for certainty.
Thanks
omer10000 said:
Part A)
Part B)
Why do parts A and B have different data?
They are just arranged in a different manner. Since I answered with their abbreviations (ie. A, B, C), it makes sense that I organize it in such a manner.
Therefore:
Part A = A B C but answer maybe B A C
Part B = A B C but answer may be B C A. If that's the case (silly me) then B and C are same then it is A but that still doesn't explain HOW Part A is B A C.
Thanks
Ps. Sorry for late reply.
Your notation is confusing. I thought A, B, and C referred to the different triplets. So the data should be consistent.
Therefore:
I will accept this as the given data.
Again, why do you think your answer A B C is wrong? (Obviously, both answers cannot be correct.)
Those answers are not compatible, so which is it?
Tell me WHY you think part A could be B A C.
You are right; A B C refer to the triplets.
I have calculated the answers using Δt' equation and have found the answer to be such but this question has already been asked (http://au.answers.yahoo.com/question/index?qid=20100914220049AAG5sHf) and propose different answers. For ease, I copy and pasted the question from the aforementioned website and that's why I had triplet information arranged in a different manner.
How I see the question is that Part A = A B C and Part B (as you have already mentioned/hinted) is pre-given in the question information = (CB), (A). Part B is calculated using the number of years they traveled as their ages is increasing relatively to the spaceships.
Thanks
Note that no explanation is given for the answers. They make no sense to me.
Right.
Alright Doc al, it seems that what we started with is what we ended with, albeit now it's much more pellucid (clear - nice word right!). To summarize what has happened in this thread:
1) Part A and Part B triplet information was rearranged and caused a misunderstanding in the interpretation of data (and it was easily overlooked that answer to Part B was already included in question information).
This was solved by making both sets of information consistent. Part A and Part B are now as follows:
∴ Part A does in fact = A B C
Part B = (BC), (A) ... BC = CB; they are the same
2) Δt' is relative to spaceship.
∴Δt' = 0.96s
Thank you for all you help Doc al, any final comments?
I'd say you got it just right.
  • · Replies 42 ·
  • · Replies 51 ·
  • · Replies 65 ·
14K
  • · Replies 26 ·
12K
