Finding the Angle of Projection for a Projectile Using Trigonometry
The problem involves determining the angle of projection for a projectile launched from ground level with a known initial velocity and horizontal distance traveled. The subject area includes kinematics and trigonometry.
  • The original poster attempts to relate the time of flight in the horizontal and vertical directions using trigonometric identities and equations of motion. They express uncertainty about their approach and seek clarification on the next steps. Other participants suggest using a trigonometric identity to simplify the problem and discuss the implications of multiple angle solutions.
Participants are exploring different methods to solve the problem, with some providing guidance on using trigonometric identities. The discussion includes consideration of multiple valid angles for the projectile's launch, reflecting a productive exploration of the topic.
The original poster notes that the back of the book provides two possible angle solutions, raising questions about the nature of the inverse sine function and its multiple outputs within the context of projectile motion.
tony873004
A projectile fired from ground level at 25 m/s hits the ground 31.25 m away. At what angle was it fired?
I wrote equations for t for both x and y
t = delta x / velocity x
t = 2 * viy/a
and set them equal to each other to eliminate t
and replaced velocityx with cos(theta)*25
and replaced velicityinitialy with sin(theta)*25
delta x / cos(theta)*25 = 2*sin(theta)*25/a
25 / cos(theta)*25 = 2*sin(theta)*25/9.81
sin(theta) * 25 * cos(theta)*25 = 153.28
My trig is not that good. How do I continue? Or is this even the right way to tackle this proble? Is there an easier way?
Assuming your previous work is correct, use the fact that sin(t)cos(t) = sin(2t)/2 to solve the last equation.
Thank you! That was exactly the trigonometry trickery I was looking for. :smile:
My problem now boils down to
[tex]\frac{sin(2theta)25^2}{2} = 153.21825[/tex]
[tex]2theta = sin^{-1} = 0.4905[/tex]
[tex]2theta = 29.37[/tex]
[tex]theta = 14.685[/tex]
The back of the book, which rounds for significant figures list 15 degrees and 75 degrees. So I got one of the two answers with this method. But sin (75*2) also equal 0.5. And it makes sense that both the 15 and 75 degree angles should yield the same result in this type of projectile problem.
So how do I make [tex]sin^{-1}[/tex] acknowledge that [tex]sin^{-1}0.5[/tex] equals both 30 (15*2) and 150 (75*2)?
for your case, [tex]0 \leq \theta \leq 90\ degree[/tex], so
[tex]0 \leq 2\theta \leq 180\ degree[/tex]
so, you have to find all the values of theta that are in the above range and you have 2 values : 30 degree and 150 degree. so theta equals to 15 degree or 75 degree.
  • · Replies 18 ·
  • · Replies 38 ·
