Proof of exp(a)exp(b) = exp(a+b)exp(1/2 [a,b])
  • Thread starter Thread starter asantas93
    Proof
The discussion revolves around proving a relation involving exponentials of operators, specifically showing that f(x) = exp(a)x exp(b) satisfies a certain differential equation and subsequently using that to establish a relationship between exp(a) exp(b) and exp(a + b) exp(1/2 [a, b]). The subject area is operator algebra and the Baker-Campbell-Hausdorff (BCH) relation.
  • Participants discuss differentiating an expression with respect to a variable x and relate it to a differential equation. There is mention of using a Taylor expansion, but one participant finds it unhelpful. Others suggest a strategy involving inserting x into the exponent and differentiating.
The discussion is active, with participants exploring different approaches to the problem. Some guidance has been offered regarding the differentiation strategy and the connection to the BCH relation, which has helped at least one participant find a proof.
There is an emphasis on the operators commuting with their commutator, and the participants are navigating the constraints of the problem without reaching a definitive conclusion.
asantas93
a, b are operators that commute with their commutator
(1) Show that f(x) = exaexb satisfies df/dx = (a + b + x[a,b])f
(2) use (1) to show that eaeb = ea+be(1/2)[a,b]
[a,[b,a]] = [b,[b,a]] = 0
I tried a Taylor expansion but just got a mess.
Did you get part (1)?
If so, the strategy is to slip an x into the exponent of the object in (2) and then differentiate it with respect to x. You should find that the object in (2) satisfies the same differential equation, with the same boundary condition, as the object in (1). It's therefore the same object. Then at the end you just set x=1 to get the answer.
Btw this is an example of a "BCH" relation (Baker-Campbell-Hausdorff) and if you search around for that you should find loads of stuff.
This is not an exercise about Taylor series, it's simply a neat trick to get a useful relation between exponentials of particular bounded operators.
Thanks, knowing the name of this sort of equation helped me find a proof.
  • · Replies 20 ·
22K
