How Far Apart Are Two -5.00 C Charges with a 4000 N Repulsive Force?
  • Thread starter Thread starter Kennedy111
    Coulomb's law Law
The distance between two charges of -5.00 C each, experiencing a repulsive force of 4.00 x 10^3 N, is calculated using the formula Fe = kq1q2/r^2. By rearranging this equation, the distance (r) is determined to be approximately 7495.83 meters, or 7.50 x 10^3 m when rounded to three significant digits. The constant k is 8.99 x 10^9 Nm^2/C^2, which is essential for this calculation. It is noted that using such large charges in electrostatics is uncommon, as practical scenarios typically involve microcoulombs (μC).
  • Understanding of Coulomb's Law and electrostatic forces
  • Familiarity with the concept of electric charge in coulombs
  • Basic algebra for rearranging equations
  • Knowledge of significant figures in scientific calculations
  • Learn about the implications of using large charges in electrostatics
  • Study the concept of electric field strength and its calculations
  • Explore practical applications of Coulomb's Law in real-world scenarios
  • Investigate the differences between microcoulombs (μC) and coulombs (C) in electrostatic problems
Students in physics, electrical engineers, and anyone interested in understanding electrostatic forces and their calculations.
Kennedy111
What is the distance between two charges of -5.00 C each if the force of electrostatic repulsion acting on them is 4.00 x 10^3 N?
q1 = -5.00 C
q2 = -5.00 C
Fe = 4.00 x 10^3
k = 8.99 x 10^9 Nm^2/C^2
Fe = kq1q2/r^2
I rearranged the equation above and got:
r = (sqrt) kq1q2/Fe
r = (sqrt) (8.99 x 10^9 Nm^2/C^2)(5.00 C)(5.00 C) / (4.00 x 10^3 N)
= 7495.832175 m
To three significant digits my answer would be 7.50 x 10^ 3 m
Hi Kennedy111,
q1 = -5.00 C
q2 = -5.00 C
Fe = 4.00 x 10^3
Fe = kq1q2/r^2
r = (sqrt) kq1q2/Fe
= 7495.832175 m
Your math and approach look fine to me. :approve:
But just for the sake of practicality, you might wish to double check that you're using the correct units from the beginning. Five Coulombs (whether negative or positive) is a lot of charge. Most charges in electrostatics problems I'm used to use units of μC.
I'm just sayin', in the system you're modeling, as you've expressed it, there is still a four kilo-Newton force between the charges, even after separating them by seven and a half kilometers (several miles). That's a lot of charge!
