Question About Light and Speed of Light
The discussion revolves around the nature of light, specifically the speed of light and the possibility of altering it through electric fields or other means. Participants explore theoretical implications and properties of light, photons, and gravity, touching on concepts from classical and quantum physics.
  • One participant questions whether the speed of light could be increased if light were charged and released near a powerful electric field.
  • Another participant asserts that light is not charged and cannot be accelerated by electric fields, emphasizing that the speed of light is a universal constant.
  • There is a query about whether light could become charged through an external factor, with a response explaining that electric charge is an intrinsic property of particles, and photons have a charge of 0.
  • Some participants discuss the effect of gravity on light, noting that while gravity does not pull on photons, light appears to bend around massive objects due to the warping of space-time.
  • A later reply challenges the idea that gravity has no effect on photons, suggesting that light's trajectory is altered by the bending of space-time.
  • Another participant clarifies that gravity does not pull on photons as if they have mass, but acknowledges that light is affected by the warping of space-time.
  • One participant introduces the idea that while the speed of light is fixed, gravity can change its direction, not its speed, and discusses the relationship between mass, charge, and speed.
  • There is speculation about the possibility of separating charge from an electron and its implications for photons, but it is noted that current science does not support such ideas.
Participants express differing views on the effects of gravity on light and the nature of electric charge in relation to photons. There is no consensus on whether light can be altered in speed or charge, and the discussion remains unresolved.
Participants reference classical and quantum physics concepts, but there are limitations in the discussion regarding the assumptions about charge and the nature of light. The implications of gravity on light and the definitions of mass and charge are also points of contention.
sjd0004
Not really sure if this is the right location for this post, but here it goes.
I have found myself becoming increasingly interested in light and wondering if the speed of light could be increased by some amount. If the light was charged, and released near a powerful electric field, could the velocity of light go beyond the speed of light as it is currently defined? This isn't for any homework or school assignment, just an idea I was curious about.
Science news on Phys.org
Light is not charged, so it can't be accelerated by electric fields. In classical physics, light IS electric (and magnetic) fields. As far as we know, the speed of light is a universal constant.
That being said, is there anyway light could become charged through an outside factor? Or is it physically impossible?
No, in quantum physics, light is made out of elementary particles called photons. Electric charge is a fundamental property of an elementary particle i.e. it's one of the characteristics that defines that particle. For example, electrons have a charge of -1, and protons +1. This, along with their masses, and other properties, is what *makes* them electrons (or protons) and not some other particle. So, since the electric charge is an intrinsic property of a a given particle you can't change the electric charge of a that type of particle: it is what it is. In the case of a photon, the charge is 0.
cepheid said:
No, in quantum physics, light is made out of elementary particles called photons. Electric charge is a fundamental property of an elementary particle (e.g. electrons have a charge of -1, and protons +1). That is to say, you can't change the electric charge of a given particle, it is what it is. In the case of a photon, the charge is 0.
Ah, I understand now. Thank you.
You are welcome! I edited my explanation a bit for clarity, but it seems it was unecessary, as you understood anyway.
While you can't charge light and somehow pull on it using an electric field, you CAN pull on it using gravity.
Nevertheless, even in a gravity field the speed of light is capped at C.
Not quite. Gravity has no effect on photons. It appears that light bends around large masses due to space-time bending. The space is bending, not light trajectory.
That's a bit of a chicken-and-egg statement. Gravity is bent space-time.
If spacetime is bent, and gravity is the manifestation of this, and lights trajectory is altered because of bent spacetime, then I would say light is affected by gravity.
What Feynman means, I believe, is that light always travels on geodesics, it's just that in some frames straight lines appear bent. But if I'm sitting near a massive object, I don't see light curving in some strange way. An observer far away does though.
You could say the same about planets orbiting the Sun gravity has no effect on them and it's due to space-time.Or an object falling on Earth there is no such thing as gravity only space-time bending.
Ok ok ok I worded it wrong. I just wanted to clarify that gravity wasn't pulling on photons, as if they have a mass or something. Yes, so gravity is bent space time, and "bent" light is a consequence of this warping. You could say that light is affected by gravity in that way, but it looks as if Lsos is talking about photons being influenced by a Newtonian view of gravity.
You realize light gravitates as well right? It contributes to gravitation, just like matter does.
...an idea I was curious about.
It's an interesting idea...never thought about that. Here are some 'deeper' considerations:
So far, as noted above already, light seems to have a universally fixed speed. While we can't currently 'charge' it electrically, also noted above, gravity does ACCELERATE it...but only by changing it's direction, not it's speed. In so far as we know, when the energy of light changes, it's frequency changes, not it's speed. [That's unique to massless entities.] And adding electric charge would appear to add energy...?? So that might not help.
We say mass can't be accelerated to the speed of light...but might there be some way to accelerate 'charge' to c?...not from current theory, because all we really know about charge so far is that it seems to be associated with mass...like in an electron or an ion.
[I checked that last comment and it seems correct:
Electric charge is a physical property of matter that causes it to experience a force when near other electrically charged matter. ...The electric charge is a fundamental conserved property of some subatomic particles,
http://en.wikipedia.org/wiki/Electric_charge] Hmmm...Charge is a 'conserved' property...Could charge be separated from an electron??...that could conserve [retain] charge, but we can't do that according to anything I know. It would no longer be an 'electron' because an electron always has charge. Could we add such separated charge 'entity' to a photon??...one problem is it would no longer be a photon...however you play with these ideas, current science does not go so far.
  • · Replies 53 ·
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 45 ·
11K
