How Do You Calculate Forces in a Two-Mass System on an Accelerating Scale-Pan?
  • Thread starter Thread starter bubakazouba
    Lift Mechanics
The problem involves a light scale pan attached to a vertical inextensible string, carrying two masses A and B, with A resting on top of B. The scenario describes the system being accelerated vertically at 0.5 m/s², prompting questions about the forces acting on the masses and the tension in the string.
  • Participants discuss the calculation of tension in the string and the forces exerted between the two masses. There is a focus on the need to consider acceleration in the calculations, with some participants questioning the original poster's reasoning regarding the forces acting on mass A.
The discussion is ongoing, with participants exploring different interpretations of the forces involved. Some guidance has been offered regarding the necessity of including acceleration in the calculations, and there is an emphasis on drawing free body diagrams to clarify the forces at play.
Participants are grappling with the implications of the upward acceleration on the forces acting on the masses, and there is a recognition of the need to apply Newton's laws appropriately. The original poster expresses confusion about the relationship between weight and the contact forces in an accelerating system.
bubakazouba
a light scale pan is attatched to a vertical inextensible sring. The scale-pan carries two masses A and B. The mass of A is 400g and the mass of B is 600g. A rests on top of B, as shown in the diagram.
The scale-pan is raised verticaly, using the string with acceleration 0.5 m/s².
a)find the tension in the string.
b)find the force exerted on mass B by mass A
c)find the force exerted on mass B by the scale-pan.
visual representation of the problem http://i1269.photobucket.com/albums/jj597/bubakazouba/test_zps62ac1992.png
F=ma
g=9.8 m/s²
I got a) correct, I just said
Tension-(0.4x9.8 +0.6x9.8)=0.4x0.5+0.6x0.5
Tension-9.8=0.5
tension =9.8+0.5=10.3N
I think the answer is mg its the weight, because its the only downward force on A so it should be 0.4x9.8=3.92, but its not right.
What am i missing here?
Thanks in advance
hi bubakazouba! :smile:
I think the answer is mg its the weight, because its the only downward force on A so it should be 0.4x9.8=3.92 …
what about the acceleration? :wink:
what about it?
bubakazouba said:
what about it?
you haven't used it
why should I use it?
i] it's in the question
ii] F = ma :wink:
I don't get it why should I use any equation, isn't it obvious the only force that acts on B is the weight, mg
that's the LHS of the equation
what about the RHS?​
what equation?
I feel so stupid right now :'(
Draw a free body diagram on A, showing the forces acting on it. Write a force balance on A, recognizing that A is accelerating upward at a rate of 0.5 m/s2.
ok I got a force 4.12N upwards what does that mean?
That's the contact force exerted by mass B on mass A. Now, from Newton's third law of action-reaction, what is the contact force that mass A exerts on mass B?
4.12?
but why, why isn't it the weight?
4.12?
bubakazouba said:
4.12?
Because mass A is accelerating upward, and so mass B has to exert enough upward contact force not only to support the weight of mass A (which would be the case if A were in equilibrium), but also to accelerate it. Also, by Newton's third law, the contact force A exerts on B is equal in magnitude and opposite in direction to the contact force B exerts on A.
