Calculus: Solving Limits with Difference of Cubes Method
  • Thread starter Thread starter a_ng116
    Calculus Limits
The discussion revolves around evaluating the limit \(\lim_{x\rightarrow 0}\frac {\sqrt[3]{1+x^2} -1}{x^2}\) using various mathematical approaches, including the difference of cubes, L'Hospital's Rule, and substitutions. The subject area is calculus, specifically focusing on limits and derivatives.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore different methods to evaluate the limit, including the difference of cubes, L'Hospital's Rule, and binomial expansion. Some suggest substitutions such as \(h = x^2\) and \(t = \sqrt[3]{1+x^2}\). Questions arise regarding the appropriateness of these methods and the interpretation of the limit in terms of derivatives.
The discussion is active, with various methods being proposed and explored. Some participants express uncertainty about their approaches, while others provide insights and clarifications. There is no explicit consensus on the best method, but several productive lines of reasoning are being examined.
Participants note that the derivative method may be considered too advanced for their current level, leading to the exploration of alternative approaches. There is also mention of specific homework constraints and preferences indicated by a teacher.
a_ng116
1) [tex]\lim_{x\rightarrow 0}\frac {\sqrt[3]{1+x^2} -1}{x^2}[/tex]
I tried doing a difference of cubes to the top and I got: [tex]\frac{\sqrt[3]{1+x^2}-1 ((\sqrt[3]{1+x^2})^2 + \sqrt[3]{1+x^2} + 1)} {x^2}[/tex]
I know you need to get rid of the [tex]x^2[/tex] on the bottom of the equation but now I'm stuck. Am I approaching this the right way and does anyone have any suggestions? Please and thank you.
L'Hospital's Rule applies:
[tex]:(1): \ \ \ \ \lim_{x\rightarrow 0}\frac {\sqrt[3]{1+x^2} -1}{x^2}[/tex]
[tex]:(2): \ \ \ \ = \ \lim_{x\rightarrow 0}\frac {(1/3)(2x)(1+x^2)^{-2/3}} {2x}[/tex]
[tex]:(3): \ \ \ \ = \ \lim_{x\rightarrow 0} {(1/3)(1+x^2)^{-2/3}}[/tex]
[tex]:(4): \ \ \ \ = \ (1/3)[/tex]
you can use binomial expansion for
[tex]({1+x^2})^{\frac{1}{3}}[/tex]
Make the subsitution [itex]h = x^2[/itex].
[tex]\lim_{h\rightarrow 0}\frac {\sqrt[3]{1+h} -1}{h}[/tex]
Does the form of the limit remind you of something familiar?
Looks like the derivative of a function at some point...
Alternatively, you could use the sub: [itex]t=\sqrt[3]{1+x^2}[/itex]
I thought I got it but I didn't. [tex]\lim_{h\rightarrow 0}\frac {\sqrt[3]{1+h} -1}{h}[/tex] looks like is from the formula [tex]\lim_{h\rightarrow 0}\frac{f(a+h)-f(a)}{h}[/tex]. Or perhaps not? Could anyone give me another hint or suggestion involving the question using the method above,replacing [tex]x^2[/tex] with [tex]h[/tex] please? Thank you very much.
You're on the right track. It does look a lot like that. Now what's f(x) and what's a? Note that [itex]f(a + h) = \sqrt[3]{1 + h}[/itex] and [itex]f(a) = 1[/itex].
--J
So working backwards I got [tex]{\sqrt[3] {x} }[/tex] . Using the formula, replacing x with a [tex]1+h[/tex] then: [tex]\frac {\sqrt[3] {1+h} - \sqrt[3] 1} {h}[/tex] which is [tex]\lim_{h\rightarrow 0}\frac {\sqrt[3]{1+h} -1}{h}[/tex]. Going back to [tex]\lim_{h\rightarrow 0}{\sqrt[3] {x} }[/tex] and replacing x with 0 gives you 0. I don't think I'm seeing it yet. Do you replace the [tex]{\sqrt[3] {x} }[/tex] back some point into the equation?
Nope. You know that the limit is the derivative of the function evaluated at the point a. f(x) indeed equals x1/3. I think you'll agree with me in saying that calculating the derivative of x1/3 is pretty easy, yes? All you have to do is evaluate the derivative of it at a.
Have you figured out what a is?
--J
could a be 1?
Yes, a is 1.
I like Galileo's method, it shows insight.
so using Galieo's method, do i replace x with 1 so [tex]\sqrt[3]1=1[/tex] ?
The method with the derivatives is interesting/ingenious,but the one using
[tex]A^{3}-B^{3}=(A-B)(A^{2}+AB+B^{3})[/tex]
is simply elegant...
So the OP needs to redo calculations...
Daniel.
The substitution [itex]t=\sqrt[3]{1+x^2}[/itex] is easiest I think.
The limit becomes:
[tex]\lim_{t\to 1}\frac{t-1}{t^3-1}[/tex]
De derivative method is cute and works sometimes, but usually a limit of this type shows up exactly when you want to calculate the derivative, so you cannot assume you know what the derivative of [itex]\sqrt[3]{x}[/itex] is.
The same is true for l'hospitals method.
You need to differentiate f(x) before you set x to a. Remember that the equation is f'(x)|x=a equals the limit, not f(a).
--J
It's more like:
[tex]f'(a)=f'(x)|_{x=a}[/tex] and NOT [tex]f'(a)=[f(a)]' (=0)[/tex]
Daniel.
Yes, of course. Must spend more time composing posts.
--J
The limit becomes:
So by using this method, taking a difference of cubes on the bottom, the limit as t approaches 1 is [tex]\frac {1}{3}[/tex] which is the same answer as by using L'Hospital's Rule such as that in post #2. I'm sorry in advance for my stupidity but the bottom (which was originally [tex]x^2[/tex] ) how did it become [tex]t^3-1[/tex] ?
i dunno... but can't u just rationalize this limit?
- Tu
Solve for x2 in the equation [itex]t = \sqrt[3]{1+x^2}[/itex] and substitute it into the denominator.
--J
Since the answer is known anyway:
if [itex]t=\sqrt[3]{x^2+1}[/itex], then [itex]x^2=t^3-1[/itex].
For the derivative method.
After the substitution [itex]h=x^2[/itex] the limit becomes:
[tex]\lim_{h \to 0}\frac{\sqrt[3]{1+h}-1}{h}[/tex]
Now the derivative of [itex]\sqrt[3]{x}[/itex] at the point x=1 is:
[tex]\lim_{h \to 0}\frac{\sqrt[3]{1+h}-\sqrt[3]{1}}{h}[/tex]
which is exactly you limit.
So the limit is equal to the value of the derivative of [itex]\sqrt[3]{x}[/itex] at the point x=1. The derivative is: [itex]\frac{1}{3\sqrt[3]{x}^{2}}[/itex], so at x=1 it's 1/3.
(Seeing it as the derivative of [itex]\sqrt[3]{x+1}[/itex] in the point x=0 works too).
I stumbled upon another way to solve this question without using the derivative method since according to my teacher, the derivative method is supposely too advanced for our level. Anyways, putting in a 1 in the bottom so it becomes:
[tex]\frac {\sqrt[3]{1+x^2} - 1}{(1+x^2)-1}[/tex]
and then taking a difference of cubes on the bottom it becomes:
[tex]\frac {\sqrt[3]{1+x^2} - 1}{(\sqrt[3]{1+x^2} -1)((\sqrt[3]{1+x^2})^2 + \sqrt[3]{1+x^2} + 1)}[/tex]
The top and bottom divide to give 1 and putting a 0 for x [tex]\frac{1}{(\sqrt[3]{1+x^2})^2 + \sqrt[3]{1+x^2} + 1)}[/tex] it gets you [tex]\frac {1}{3}[/tex] also.Apparently,this was the way my teacher wanted us to do it. Well, enough of my rambling. Thank you all for your patience and taking the time to assist me. Cheers.
This is exactly the same as substituting [itex]t=\sqrt[3]{1+x^2}[/itex], it's just easier to spot that: [itex](t^3-1)=(t-1)(t^2+t+1)[/itex]
instead of:
[tex](1+x^2)-1=(\sqrt[3]{1+x^2} -1)(\sqrt[3]{1+x^2})^2 + \sqrt[3]{1+x^2} + 1)[/tex]
[/end nonconstructive post]
  • · Replies 16 ·
  • · Replies 19 ·
