How is charge/mass ratio derived in this example?
  • Context: Undergrad
  • Thread starter Thread starter SlothNast
    Example Ratio
The charge-to-mass ratio (q/m) can be derived using the equations of motion and energy in electromagnetic fields. The key equations involved are (1/2)mv² = qV and qvB = (mv²)/r. By substituting the expression for velocity (v) from the second equation into the first, the final expression for the charge-to-mass ratio is q/m = (2V) / (B² x r²). This derivation highlights the relationship between charge, mass, velocity, voltage, radius, and magnetic field strength.
  • Understanding of classical mechanics, specifically Newton's Second Law.
  • Familiarity with electromagnetic theory, particularly the Lorentz force.
  • Knowledge of kinetic energy equations and their applications.
  • Basic algebra for manipulating equations and solving for variables.
  • Study the derivation of the Lorentz force and its implications in charged particle motion.
  • Learn about the work-energy theorem and its application in electromagnetic contexts.
  • Explore the concept of cyclotron motion and its relevance to charge-to-mass ratios.
  • Investigate experimental methods for measuring charge-to-mass ratios in particle physics.
Students and professionals in physics, particularly those focusing on electromagnetism, particle physics, and classical mechanics. This discussion is beneficial for anyone looking to understand the derivation of charge-to-mass ratios in electromagnetic contexts.
SlothNast
How is charge/mass ratio derived in this example??
Hello, I know there are many ways to derive an expression for "q/m", but I am having some troubles with this one. We are given:
(1/2)mv^2 = qV (mass, velocity, charge, voltage)
qvB = (mv^2) / r (charge, velocity, mag field, mass, velocity, radius of arc)
r = (mv) / (qB) (radius, mass, velocity, charge, mag field)
given these equations, we are supposed to come up with:
q/m = (2V) / (B^2 x r^2) (chargemass = 2Voltage / (mag field)^2 times (radius)^2)
Its probably a very simple step, I just don't see it. Any help is greatly appreciated, Thanks!
You have 2 eqns. and 6 quantities (mass, charge, velocity, voltage, radius and mag. field), but charge and mass in both of the eqns. occur as a combination x = q/m. In terms of this ratio, your eqns. read:
(1/2) v2 = x V
x B = v/r
You can use 2 eqns. to eliminate 2 out of 5 unknowns. You do not know x! Also, your final result does not contain velocity v. So, I would suggest you solve the 2nd eqn. for v, substitute that in the 1st eqn. and then solve it for x = q/m. Your answer should depend on r, B and V.
Edit:
Whenever you use 2nd Newton's Law (2nd eqn.) or the work-energy theorem (1St) and the only forces are electromagnetic (proportional to the charge q of the particle), you are guaranteed that charge and mass enter as a combination q/m. This is because each of this equations is of the form l.h.s. = r.h.s. and l.h.s. is proportional to m (the m*a in Newton's Law or (1/2)m*v2 for the kinetic energy in the work-energy theorem), while r.h.s. is proportional to q (for an electromagnetic force, or the work done by the electric field).
just put the value of velocity from second eqn. into first eqn.(from radius to kinetic energy)
  • · Replies 19 ·
