Elastic vs. Inelastic Collisions: Which is Better for Diverting an Asteroid?
  • Thread starter Thread starter ahhppull
    Collision
The discussion centers on the effectiveness of elastic versus inelastic collisions for diverting an asteroid. Participants agree that an inelastic collision is preferable for maximizing momentum change, as it allows the projectile to transfer its momentum to the asteroid without rebounding. Concerns are raised about the feasibility of achieving an inelastic collision, while elastic collisions may result in the projectile being redirected towards Earth. The consensus is that inelastic collisions require less force to achieve the desired deflection of the asteroid.
  • Understanding of momentum transfer in physics
  • Knowledge of elastic and inelastic collision principles
  • Familiarity with projectile motion concepts
  • Basic grasp of force and acceleration relationships
  • Research the physics of inelastic collisions and their applications in asteroid deflection
  • Explore momentum conservation laws in both elastic and inelastic scenarios
  • Investigate methods for calculating the required force for asteroid deflection
  • Learn about current NASA projects related to asteroid impact prevention
Scientists, engineers, and students interested in planetary defense, particularly those focused on asteroid impact mitigation strategies.
ahhppull
Let’s say you’re a scientist or engineer working for NASA and you are tasked with the responsibility of diverting an asteroid heading straight for Earth. You know that you must fire a projectile to deflect the asteroid as much as possible (without breaking it into many Earth-destroying pieces!). In the hopes of changing the asteroid’s momentum by the greatest amount, would you want your projectile to make an elastic or inelastic collision with the asteroid? Briefly explain.
I thought that making an inelastic collision would be the best, but probably impossible. Also if we make an elastic collision, wouldn't the projectile head towards Earth after it collides with the asteroid?
I want to hear your opinions on this.
Which requires more force.
1. Stop the projectile with a velocity of v (inelastic collision).
2. Stop the projectile with a velocity of v and then speed up the same projectile with a velocity of v in the opposite direction (elastic collision).
  • · Replies 16 ·
16K
