Understanding Electric Field: Definition, Formula, and Limit Explained
The discussion revolves around the concept of electric fields, specifically the definition and implications of using a test charge to measure the electric field produced by other charges. Participants are exploring the conditions under which the test charge can be considered infinitesimal and the effects of stationary versus moving charges on the configuration of the electric field.
  • Participants are attempting to understand the role of the test charge in measuring electric fields, questioning why an infinitesimal charge is necessary when the source charges are stationary. They are also exploring how a test charge could potentially alter the configuration of other charges.
The discussion is ongoing, with participants seeking clarification on the relationship between the test charge and the electric field. Some guidance has been provided regarding the purpose of the test charge and its role in measuring pre-existing fields, but questions remain about the conditions under which the test charge can be larger without affecting the field.
Participants are considering the implications of using a test charge in different scenarios, particularly in relation to static and moving charges, and the potential effects on the electric field configuration. There is a focus on understanding the assumptions made in the context of the problem.
Von Neumann
1. Electric field caused by a charge (or group of charges) is defined in terms of its effect on a test charge, given by the formula: E ⃗=lim┬(q_(0→0) )⁡〖F ⃗/q_0 〗
I understand that the point charge must be infinitesimally small in order not to affect the field in question, so it makes sense to take the limit of q[itex]_{0}[/itex] to 0. However, I do not understand why my book states the following: "If the charge(s) creating the field could be considered fixed in place, then we would not have to assume the test charge is small." Can someone please clarify?
Hello Von Neumann. Welcome to PF !
It's not that the "test charge", q0, changes the field by producing a field of its own, it's that the test charge may alter the field produced by the other charges, if it, q0, alters the configuration of the other charges. That's particularly a problem if the field is produced by charges on a conductor.
Thanks for the reply, and I'm glad to be a part of PF!
I'm still confused on this, though. You say that the test charge, q0, does not change the field by the production of its own electric field, and that the problem to consider is the test charge altering the configuration of other charges. However, how is it possible for the test charge to alter the configuration of other charges without an electric field of its own to exert a force in order to cause such an alteration? Additionally, going back to my original question, why is the charge not required to be infinitesimal for the case when the charges are stationary?
I suppose I could have made my statement clearer.
The purpose of the test charge is to detect whatever electric field was present prior to the test charge being introduced into the situation. You're not interested in the field produced by the test charge.
Suppose you place a test charge, q0, into a pre-existing static electric field, E. The force, F, exerted on the test charge by the pre-existing static electric field, is F = q0E, and that has no dependence upon any electric field produced by the test charge. Yes, placing the test charge at a location will alter the electric field, but the purpose of the test charge is to measure the field which existed prior to introducing the test charge. If the locations of the charges producing the pre-existing electric field are unaltered by the introduction of the test charge, then F/q0 gives an accurate measure of pre-existing electric field at the location of the test charge.
However, if the charges producing the pre-existing electric field can have their locations altered by the field produced by introducing the test charge, then you want to use as small a test charge as is practical, or better yet, if you can do it, use a sequence of test charges to determine [itex]\displaystyle \lim_{q_0\,\to\,0\,}\, \frac{\textbf{F}}{q_0}\ .[/itex]
So basically, in the case that you are calculating the pre-existing electric field produced by static charges, the test charge does not alter the configuration and therefore does not need to be infinitesimal. Additionally, in the case that you are calculating the electric produced by moving charges, the test charge does alter the configuration and does need to be infinitesimal. Is this right? I'm not sure whether an altering of the configuration of charges depends on the magnitude of the pre-existing electric field or a velocity associated with the charges. Why not always use a sequence of test charges to be sure that the configuration of charges does not alter?
  • · Replies 26 ·
