| New Reply |
Tempering of martensite with retained austenite |
Share Thread | Thread Tools |
| Oct26-12, 02:58 AM | #1 |
Hi,
What changes will happen to retained austenite in a martensite matrix during tempering of martensite in an alloy steel @740 C-760 C (ie, below Ac1 temperature)?Will retained austenite transform to martensite (untempered) during tempering or retained austenite will stay as it is during tempering??Is there any possibility for a transformation from retained austenite to pearlite/bainite during tempering??I am confused Any help would be highly appreciated.PS:I am not looking for a cryogenic treatment to transform all retained austenite to martensite and further tempering solution to this problem. Thanks |
| Oct27-12, 01:15 AM | #2 |
,119 views,no reply (right or wrong)so far.I never thought that this was a much complicated question!
| Oct27-12, 04:27 PM | #3 |
During heating, as in tempering, the retained austenite may form pearlite but will NOT form martensite. Martensite formation is diffusionless and shear-dominated, and therefore some combination of quenching and/or deformation is needed. In short, it is not possible to 'heat' a phase and convert it to Martensite. Or Bainite, for that matter since it too requires a fast quenching rate to form, although not as severe a rate as martensite.
| Oct28-12, 01:38 PM | #4 |
Admin
Tempering of martensite with retained austeniteMartempering occurs at rather low temperatures. A steel could be quenched into the martensite region then brough up into a temperature to promote bainite. Here is some information from various sources: The effect of tempering depends on the alloy composition, soak time (time at temperature), and quench rate. http://www.azom.com/article.aspx?ArticleID=313 Some steels are deliberately austenitic, ferritic or martensitic, or some combination, e.g., duplex. Their processing will depend on composition, e.g., content of carbon and elements that promote stabilization of one of the microstructures, e.g., austenite. Tempering Processes/Technology - ASM International http://www.asminternational.org/pdf/.../tempering.pdf Austenitic and Ferritic Stainless Steels in Practical Applications: Part One http://www.keytometals.com/page.aspx...ite=kts&NM=156 Martensitic Stainless Steels http://www.keytometals.com/page.aspx...ite=kts&NM=199 http://www.asminternational.org/port...0aRCRD#details http://www.advancedcast.com/austempering-process.htm The austempering process http://www.appliedprocess.com/process Examples http://www.appliedprocess.com/adi http://www.appliedprocess.com/as Marbain process http://www.fisherbartonsp.com/products/products.php Some other information http://www.msm.cam.ac.uk/phase-trans...stainless.html A practical application: Bainite and austempered ductile iron combined in high-strength steel http://www.asminternational.org/port...00621e010aRCRD |
| Oct30-12, 07:50 AM | #5 |
Thanks Bavid and Astronuc for the reply. That means, during tempering cycle (ie, heating), retained austenite will not transform to martensite(ie, no possibility for lattice shear and the temperature is well above Ms temp.). Still the possibility of Austenite decomposition to ferrite and carbide during tempering heating cycle depends on tempering temperature and holding (soaking) time. The martensite will get tempered during tempering cycle. During cooling, below Ms Temperature, the remaining conditioned retained austenite (if it is available, much of carbon depleted from retained austenite during tempering thus Ms Temperature of alloy further raised) will transform to hard and brittle martensite. So, I think, I need one more tempering cycle to temper the secondary martensite.
| Oct30-12, 08:16 AM | #6 |
If it is plain carbon steel, Austenite is way too unstable to exist at the tempering temperature. I obviously do not know the tempering time you are using, but if you steel is plain carbon, you can very quickly convert ALL of the retained austenite to ferrite+pearlite, so when you quench for another cycle it is possible that there is no austenite left to form the 'secondary martensite' you mention.
| New Reply |
| Thread Tools | |
Similar Threads for: Tempering of martensite with retained austenite
| Tempering and what it means to 'draw it' | Materials & Chemical Engineering | 0 | ||
| Finding kinetic energy retained by an object after an elastic head-on collision | Introductory Physics Homework | 1 | ||
| Lattice constant of martensite? | Atomic, Solid State, Comp. Physics | 2 | ||
| Austensite to Martensite Transformation | Materials & Chemical Engineering | 2 | ||
| tempering simulator | Materials & Chemical Engineering | 2 | ||
