How would vehicles for Mars differ from Earth's?
  • Thread starter Thread starter CCWilson
    Mars Vehicles
The discussion revolves around the design and functionality of vehicles and heavy equipment intended for use on Mars, particularly in the context of its cold, airless environment. Participants explore various power sources, materials, and engineering considerations necessary for such vehicles, including the challenges posed by extreme temperatures and the absence of an atmosphere.
  • Homework-related
  • Some participants express concerns that Earth-built vehicles may not function effectively on Mars due to freezing lubricants and fuels.
  • There is a suggestion that electric power could be advantageous for Mars vehicles, as it is easier to transport and can be generated in situ.
  • One participant inquires about the design of heavy equipment like bulldozers, questioning the need for lubrication and the potential for using strong materials that function without it.
  • Another participant mentions that internal combustion engines (ICEs) could theoretically operate in a vacuum if provided with air and fuel supplies, but questions the practicality of such designs.
  • Discussion includes the potential use of nuclear batteries and the feasibility of using hydrogen fuel cells for long-distance travel on Mars.
  • Participants mention the use of radioisotope thermoelectric generators (RTGs) as a possible power source, highlighting their ability to generate electricity from radioactive decay.
  • There are references to existing designs and technologies, such as the Mars Rover and space probes, which could inform the development of Mars vehicles.
  • One participant emphasizes the need for a purpose-built vehicle capable of carrying substantial weight over long distances without solar power.
Participants do not reach a consensus on the best approach for designing vehicles for Mars. Multiple competing views on power sources, materials, and engineering strategies remain, with ongoing questions about the practicality and effectiveness of various proposed solutions.
The discussion highlights the broad scope of engineering challenges associated with designing vehicles for Mars, including the need for specific mission profiles and the limitations of current technologies. There are unresolved questions regarding the efficiency and safety of different power sources and materials in the Martian environment.
Writers, engineers, and enthusiasts interested in space exploration, vehicle design, and the challenges of operating in extraterrestrial environments may find this discussion informative.
CCWilson
I'm sure that Earth-built vehicles and heavy equipment wouldn't function in the cold of an airless planet or moon because all lubricant and fuel would freeze, among other issues. So how do you design vehicles and other equipment for transportation and work in those environments? Would electric power be the way to go? Would internal combustion engines work, if insulated?
You design the vehicles to cope with the environments by carefully considering the environment in terms of the mission profile and available materials of course.
I'm afraid the question is too broad.
We use electricity because it is cheap to transport and more can be made in situ.
It is technically possible to make ICEs that work on Mars, but why would you want to?
Is there something in particular you are thinking of?
I'm writing a story and need more general information than I have about how vehicles and equipment - especially heavy equipment like bulldozers or well-diggers - could be designed to function on an airless planet. Would gears and articulated arms and such need to be lubricated and thus insulated, or are there strong materials that glide over each other well enough without lubrication and would hold up at temperatures near absolute zero? Are there energy sources other than batteries that could put out the massive power needed to drive heavy equipment? I confess almost total ignorance on these issues.
If someone knows of a white paper or article or textbook that discusses this subject in a way understandable to a layman, I'd appreciate it. Thanks.
You can run an ICE in vaccuum, for eg, the same way you run a human - put it in a box with air and fuel supplies and some way to keep cool.
There are ceramics that make joints that don't need to be oiled.
The Mars Rover uses aerospace bearings and lubrication is one of the concerns.
http://www.nasaimages.org/luna/servlet/view/search/what/Sun/Hazard-identification+Camera/Spirit?q=+Mars+Rover&os=0&pgs=50&sort=Title%252CDate
There are endless clever ways to get lubricant to bearings.
You probably want to look into the design of space probes - NASA is the place to start.
Voyager went a long way and had a few moving parts.
The various rovers' designs are well discussed.
You have to narrow your spec somewhat - are these vehicles expected to be manned? How long do they need to run for? How big? How much work does it have to do?
For an example of a light 2-man transport for an airless environment - have a look at the LRV design.
For power sources - probes often use nuclear batteries.
There is nothing especially wrong with using electric power to do heavy work.
There are already electric drive systems for heavy machinery like bulldozers - run on hybrid technologies.
For pure SF you way want to look at the SF RPG resources around - GURPS Space is handy, covering current to advanced tech.
What you won't find is a single (lay) paper discussing the field - it is too broad.
Google for "how to engineer for space challenges" and similar terms and you'll get lots of specifics.
Many thanks, Simon. I'm looking into all your suggestions. Here's what I need: a vehicle to carry substantial weight, including an operator, over long distances (hundreds - maybe even thousands - of miles) - and here's the kicker: no sun, so no solar power! I suspect that a fuel cell - hydrogen or otherwise - might be my best bet - although I wonder if an insulated, oxygen-fed internal combustion engine might give greater range. I assume that nuclear batteries would be underpowered but I'd be happy to learn otherwise. Thoughts?
The machine would be purpose-built for this, or you imagine that it has to do that trek in an emergency?
You want a space version of one of these:
http://www.chinabzk.com/bzk/en-us/product/D20.htm
... the engine has a max power of 187kW.
Maybe smaller? Bigger? But looking at a terrestrial design for parameters would be a good place to start.
Nuclear power generation:
https://netfiles.uiuc.edu/mragheb/www/NPRE%20402%20ME%20405%20Nuclear%20Power%20Engineering/Radioisotopes%20Power%20Production.pdf
Air independent propulsion:
http://en.wikipedia.org/wiki/Air-independent_propulsion
Engineers would have several years to develop the vehicle. A little Google research and I'm leaning toward an RTG (radioisotope themoelectric generator) power source to charge batteries to run an electric engine. That's a concept that was new to me but is very interesting. As you probably know, the heat from the isotope's decay would generate electricity through the use of thermocouples. The ideal isotope to use, apparently, is Plutonium 238, whose radioactivity is not dangerous unless inhaled or ingested. The US has stopped production of Pu 238 and would have to restart it if we ever decided to actually develop such automobiles - which is very unlikely - but might be the best option for my story.
RTGs are neat :)
I once worked out what it would take to power my house on one (not cost effective).
The big bottleneck, technically, is on the T part.
Note: if you also had large-scale nuclear power generation, the waste products could be used to fuel RTGs.
Looking at the figures - and applying them to the power-stage of the Dozer (link above), you'd need:
623 Cassini-style units - about 4.8T just in fuel.
(There's a pic of one in the wikipedia page)
62 BES5-type units and 1.9T in fuel.
BTW: since it is a story you can always look at ideal Carnot cycle engines or Stirling Engine.
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 98 ·
12K
  • · Replies 23 ·
