Conversion to closed-form expression with DE's
  • Context: Graduate
  • Thread starter Thread starter Trifis
    Expression
The discussion revolves around the possibility of obtaining closed-form solutions expressed with elementary functions from differential equations derived from implicit functions. Participants explore the implications of the implicit function theorem, Galois theory, and the limitations of closed-form expressions in the context of differential equations and specific examples.
  • One participant questions whether a solution expressed with elementary functions can be obtained from an implicit function F(x,y)=0, suggesting that while a function y(x) exists near (0,0), the method may not yield a closed-form solution.
  • Another participant argues that the definition of "closed form" is subjective, noting that integrals, infinite series, or differential equations can sometimes be considered closed forms, depending on context.
  • A participant provides an example involving the equation F(x,y)=lny+y-x, stating that while it is solvable near (1,1), the solution involves the Lambert function, which cannot be expressed in elementary terms.
  • There is a consensus among participants that Galois theory can demonstrate the impossibility of finding certain closed forms, but this is specific to particular functions and contexts.
  • Another participant emphasizes that the Lambert function is necessary for solving certain equations, indicating that some problems cannot be resolved using elementary functions alone.
Participants express differing views on what constitutes a closed-form solution, with some arguing that integrals and series can qualify, while others maintain that they do not. There is no consensus on the feasibility of obtaining closed-form solutions from the discussed methods, and the discussion remains unresolved regarding the broader implications of Galois theory.
Participants acknowledge limitations in their understanding of algebraic Galois theory and differential extensions, suggesting that their conclusions may depend on further exploration of these topics.
Trifis
I was wondering, if it is possible to obtain somehow a solution expressed with elementary functions from an equation, which is in non closed-form at first sight.
For istance let us consider an implicit function F(x,y)=0 with Fx(0,0)≠0, which can't be explicitly solved for y. Nevertheless, according to the implicit function theorem, a function y(x) exists in the neighbourhood of (0,0). We also know from the same theorem that yx(x)=-Fx(x,y)/Fy(x,y).
One could now claim that the differential equation dy/dx=g(x,y) (whereby g(x,y)=-Fx(x,y)/Fy(x,y)) could have a closed-form solution for y!
The odds are that this method would never yield any result. If that is the case, can sb, more familiar with the Galois theory or the theory of functions, provide us with a justification/proof?
It depends what is meant by closed form and at first sight.
For some purposes an integral, infinite series, or differential equations is a useful answer to a question and can be considered a closed form. Many textbook problems are silly when seen this way. One might be asked to write an integral as an infinite series, but it is not clear that it is an improvement. Often some clever use of an identity can allow a closed form that is not obvious at first. You are right Galois theory allows one to prove that a closed form does not exist. This holds only for that particular closed form, add some more functions and everything changes.
see
http://en.wikipedia.org/wiki/Differential_Galois_theory
http://www.math.huji.ac.il/~kamensky/lectures/diffgalois.pdf
http://www-math.upb.de/~acrowley/Studium/img/DiffGal.pdf
For instance the equation F(x,y)=lny+y-x is solvable for y near (1,1) but this solution, the so-called the Lambert function, cannot be expressed in terms of elementary functions.
According to the method I described, the respective DE we get is: (y+1)y'=-y which has exactly the same solution. So there is nothing gained of course from this attempt.
Generally, integrals and series are not considered closed forms.
I guess "at first sight" would mean that our F is not explicitely solvable for a variable, but after some kind of transformation, we could "unravel" an elementary solution. I'm pretty much a beginner with the algebraic Galois theory let alone the differential extension, but the more I read the more obvious it becomes that sth like that is impossible.
Galois theory just allows one to be sure something is impossible. There is nothing special about elementary functions. If you need to solve log y+y-x=0, you need the Lambert function (or similar). Later, maybe you need to solve log y+sin y-x=0 and the Lambert function is not enough. There is no way to get around these things.
  • · Replies 19 ·
  • · Replies 16 ·
