Box moving on a decelerating truck?
  • Thread starter Thread starter dtseng96
    Box Truck
The problem involves a truck that is decelerating while carrying a wooden box. The objective is to determine the maximum distance the truck can travel before the box hits the cabin, taking into account the coefficients of friction between the box and the truck bed.
  • The original poster attempts to understand the reasoning behind the acceleration values provided by their teacher, specifically how the acceleration of the box relative to the truck is derived. Some participants question the phrasing of the problem regarding the maximum versus minimum stopping distance, while others reflect on the implications of deceleration rates on the box's movement.
Participants are actively engaging with the problem, seeking clarification on the concepts involved. There is acknowledgment of potential errors in the teacher's solution, and some guidance has been offered regarding the interpretation of the problem's requirements. Multiple interpretations of the stopping distance are being explored.
There is a mention of the relationship between static and kinetic friction coefficients, which may influence the understanding of the box's behavior on the truck bed. The original poster also references a specific part of their teacher's solution for further context.
dtseng96
A truck with a steel bed carries a wooden box, where μs = 2μk. The box of mass m is in the middle of the bed of length l. If the truck is moving forward with velocity vo but is slowing down, determine the maximum distance the truck can take to stop before the box hits the cabin of the truck in terms of the variables given.
F = ma, Fk = μkmg
So my teacher said that the acceleration of the box relative to the truck is aB = μkg, while the acceleration of the truck relative to the ground is aT = -μkg. I'm having trouble understanding how my teacher got this... I do know that the acceleration of the block relative to the ground is a = μg, but I don't know how my teacher got the acceleration of the block relative to the truck. Can anyone help clarify my teacher's reasoning?
Any help is appreciated. Thank you so much!
In case you guys want to look at my teacher's actual solution, here it is. My question is about part b): https://dl.dropbox.com/u/12682457/m%20%26%20f%20%232%20copy.jpg
You wrote,
"...determine the maximum distance the truck can take to stop before the box hits the cabin..."
Shouldn't that be the minimum distance the truck can take to stop? If we decelerate slowly the box won't move relative to the truck.
Edit, ignore the above question, it now makes sense to me.
Does this look right?
@Spinnor: Yes, that does look correct to me! :) Except the question is looking for the maximum distance the truck travels :O
I discussed this again with my teacher, and apparently, there might be a mistake in my teacher's work. But yes, thank you for your solution! It gave me an idea of what the correct solution should look like...
17K
14K
12K
12K
