Differential Geomtery. Find the vertices the equation
  • Context: Graduate
  • Thread starter Thread starter ocho
    Differential
The discussion focuses on finding the vertices of the curve defined by the equation α(t) = 1 - 2 cos(t). To determine the vertices, participants emphasize the necessity of setting the curvature to zero, defined by the formula Curvature = ||α'(t) x α''(t)|| / (||α'(t)||^3). The conversation highlights the importance of understanding the first and second derivatives of α, as well as the context of the curve, whether it exists in a plane or in three-dimensional space.
  • Understanding of differential geometry concepts
  • Familiarity with curvature calculations
  • Knowledge of vector calculus, specifically derivatives
  • Ability to interpret parametric equations
  • Study the calculation of curvature in differential geometry
  • Learn about parametric equations and their derivatives
  • Explore vector calculus techniques for cross products
  • Investigate the geometric interpretation of vertices in curves
Mathematicians, physics students, and anyone interested in advanced geometry and calculus, particularly those working with curves and their properties.
ocho
Find the vertices of α(t) = 1 - 2 cos(t)
I know that to find the vertices we have to set the curvature equal to zero.
I know the first and second derivative of α. But I feel like I am missing something. Should I do a step before taking the derivatives.
Thanks
Hey ocho and welcome to the forums.
If you can do the problem correctly in one go, then just do it and if you're concerned check it afterwards (possibly with another attempt that breaks things up a bit).
Math is math and if you know what's going on and what's happening then the answer is the answer and one that is based on understanding and proper technique.
Maths is fortunate (like anything really) in that you can obtain the answer in many different ways since there is no one method that is prioritized to give an answer that no other method will not, so if you choose a way to solve something based on sound principles and technique, then that's what really matters.
Thanks
I don't see what the curve is. Is it in the plane or in 3 space? What you wrote down just seems to be a function.
  • · Replies 25 ·
