How Accurate Are My Physics Problem Solutions?
  • Thread starter Thread starter woodworker101
    Airplane
The discussion revolves around the application of Newton's laws of motion in various physics problems. The original poster expresses uncertainty about their solutions to problems involving forces, acceleration, and friction, seeking validation and insight from others.
  • The original poster attempts to verify their answers to multiple physics problems, including calculating acceleration and the coefficient of friction. They express a desire to understand their mistakes by comparing their work with others.
Some participants question the correctness of the original poster's answers and encourage them to share their work for further examination. There is a focus on understanding the reasoning behind the answers rather than simply confirming them.
The original poster indicates a lack of confidence in their solutions and seeks peer input to clarify their understanding. There is an implication that the discussion is part of a homework assignment, which may impose certain constraints on the types of assistance that can be provided.
woodworker101
I am still having troubles with Newtons laws and i work with the problems but get an answer but don't know if it is the right one and just want to check my work with yours to see if I am correct.
An airplance with a mass of 1.2 x 10^4 kg tows a glider with a mass of .60 x 10^4 kg. If the airplace propellers provide a net forward thrust of 3.6 x 10^4 N, what is the acceleration of the glider? I believe the answer is 6.0 m/s^2, but not for sure if it right or not.
An Olympic skier moving at 20.0 m/s down a 30.0 degree slope encounters a region of wet snow and slides 145 m before coming to a halt. What is the coefficient of friction between the skies and the snow? I believe it is .740.
Two perpendicular forces, one of 45.0 N directed upward and the second of 60.0 N directed to the right, act simultaneously on an object with a mass of 35.0 kg. What is the magnitude of the resultant acceleration of the object? This I believe is 1.41 m/s^2.
All I am wanting is to see someone else's work on how they got their answer so I can see where I messed up or if I did them correctly or not. Thanks for the help.
Your first and third are wrong. Why don't you show your work and we see what you did wrong?
--J
The reason is that when I tell someone else my work it doesn't make sense to them and I just started to ask to see someone elses to see where my mistake(s) where. that is the reason behind it.
Have you not convinced yourself that your answer is totally correct? If not, why not? You shouldn't be able to spot problems in your own work by looking at others', you should be able to spot problems in others' work by looking at others'. Barring silly algebra mistakes, of course.
Show your work.
--J
  • · Replies 21 ·
  • · Replies 16 ·
