Find speed given mass, force, and distance
The speed of an 88-g arrow fired from a bow with an average force of 110 N over a distance of 78 cm can be calculated using two methods: Newton's second law (F=ma) and the work-energy principle (W=Fd). By applying F=ma, the acceleration is determined as a = F/m, and then the final velocity is calculated using the equation v² = u² + 2as, where the initial velocity (u) is zero. Alternatively, the kinetic energy can be calculated using W=Fd, and then the speed can be derived from the kinetic energy formula. Both methods yield the same result, confirming the accuracy of the calculations.
  • Understanding of Newton's second law (F=ma)
  • Familiarity with equations of motion for constant acceleration
  • Knowledge of work-energy principle (W=Fd)
  • Basic concepts of kinetic energy and its relationship to velocity
  • Study the derivation and application of Newton's second law in various contexts
  • Learn about equations of motion and their applications in physics problems
  • Explore the work-energy theorem and its implications in mechanics
  • Investigate kinetic energy calculations and their relevance in projectile motion
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of motion and energy in projectile dynamics.
nPwn
1. An 88-g arrow is fired from a bow whose string exerts an average force of 110 N on the arrow over a distance of 78 cm. What is the speed of the arrow as it leaves the bow?
2. I'm completely lost, sorry!
You know the force and mass of the arrow, so you can calculate the acceleration:
F=ma
then using equations of motion for constant acceleration, meaning the force providing the acceleration doesn't change throughout the motion.
v^2 = u^2 +2as,
v=final velocity, u = intial velocity=0, a=(f/m), s is distance over which the object is accelerated.
ill check your answers once you have applied yourself :).
DannyR's answer is right, but it's not the only possible way of solving the problem.
You could also use W=Fd to calculate the kinetic energy of the arrow, use the formula for kinetic energy as a function of velocity to get the speed. An easy way to check your work is to see if you get the same answer both ways.
