Solving a Force Problem: Finding the Angle of a Hanging Object
  • Thread starter Thread starter Flaming Toilet
    Force
The problem involves determining the angle that a string makes with the vertical when a pair of fuzzy dice is hanging from it while the car accelerates. The context is rooted in dynamics and forces acting on objects in motion.
  • Mixed
  • The original poster attempts to calculate acceleration and draw a force diagram but expresses uncertainty about the next steps. Some participants suggest considering the components of tension and weight, while others discuss the equilibrium state of the fuzzy dice and the use of trigonometry to find the angle.
Participants are exploring different methods to approach the problem, including the use of trigonometric relationships and Newton's Second Law. There are multiple interpretations of how to relate the forces involved, and while some calculations are presented, there is no explicit consensus on the final angle.
There is a focus on the balance of forces and the relationship between tension, weight, and acceleration. The discussion includes various assumptions about the system's state and the forces acting on the hanging object.
Flaming Toilet
Here's the question: A pair of fuzzy dice is hanging by a string from your rearview mirror. While you are acclerating from a stoplight to 20.0 m/s (in 5.0 sec.), what angle theta does the string make with the vertical?
Ok, I drew a force diagram with F (tension; upward direction)on the string and mg (weight) going down. Then, I found acceleration using the Vf-Vi divided by time : a=(Vf-Vi)/t
a=(20.0 m/s - 0 m/s)/5.0 s
a= 4.0 m/s squared
However, I have no idea what to do next. Can anyone give a hint(s) on what to do next?
Think in terms of components.
Since there is no vertical motion of the fluffy dice, the vertical component of the tension must equal the weight of the dice.
There horizontal acceleration which you calculated must also be supplied by the tension in the string.
Since you know the two components of force supplied by the tension in the string, you can work out which direction the tension (and hence the string) must be pointing in.
Claude.
First, it is important to note that the fuzzy dice is in a state of equilibrium, meaning that the forces acting on it are balanced. This means that the tension force (F) is equal in magnitude and opposite in direction to the weight force (mg).
To find the angle (theta) of the string with the vertical, we can use trigonometry. We know that the vertical component of the tension force is equal to the weight force, and the horizontal component of the tension force is equal to the acceleration multiplied by the mass of the dice (F=ma).
Using the Pythagorean theorem, we can find the magnitude of the tension force:
F = √(Fy^2 + Fx^2)
F = √(mg^2 + ma^2)
F = √(0.2kg * 9.8m/s^2)^2 + (0.2kg * 4m/s^2)^2)
F = √(3.92N^2 + 0.64N^2)
F = √4.56N^2
F = 2.135N
Now, we can use trigonometry to find the angle theta:
sin(theta) = opposite/hypotenuse
sin(theta) = mg/F
sin(theta) = 0.2kg * 9.8m/s^2 / 2.135N
sin(theta) = 0.2kg * 9.8m/s^2 / 2.135kg * m/s^2
sin(theta) = 0.2/2.135
sin(theta) = 0.0936
theta = sin^-1(0.0936)
theta = 5.37 degrees
Therefore, the string makes an angle of approximately 5.37 degrees with the vertical while accelerating from a stoplight to 20.0 m/s in 5.0 seconds.
To solve this problem, we can use the concept of trigonometry. First, let's identify the unknown variables in this problem. We have the acceleration (a=4.0 m/s^2), the initial velocity (Vi=0 m/s), and the final velocity (Vf=20.0 m/s). The only unknown variable is the angle theta (θ) that the string makes with the vertical.
To find the angle theta, we can use the trigonometric relationship of tangent (tan). In this case, tanθ = opposite/adjacent. The opposite side is the tension force (F) and the adjacent side is the weight force (mg). Therefore, we can write the equation as:
tanθ = F/mg
Next, we need to find the value of the tension force (F). We can use Newton's Second Law, which states that the net force on an object is equal to its mass (m) multiplied by its acceleration (a). In this case, the only force acting on the fuzzy dice is the tension force (F). So we can write the equation as:
F = ma
Substituting this into our previous equation, we get:
tanθ = ma/mg
Simplifying this further, we get:
tanθ = a/g
Now, we have all the known variables to solve for the angle theta. We know the value of acceleration (a=4.0 m/s^2) and the acceleration due to gravity (g=9.8 m/s^2). So we can substitute these values into the equation and solve for theta:
tanθ = 4.0 m/s^2 / 9.8 m/s^2
θ = tan^-1(0.408)
θ = 22.6°
Therefore, the angle that the string makes with the vertical is approximately 22.6°. This means that the fuzzy dice is tilted at an angle of 22.6° while the car is accelerating from 0 to 20.0 m/s in 5.0 seconds.
