Classify the equlibrium points of the system-Pls help me, its
  • Thread starter Thread starter rakhi
    Equlibrium Points
The discussion revolves around classifying the equilibrium points of a dynamical system defined by two differential equations. The original poster expresses difficulty in understanding the concept of classification in the context of an upcoming math exam.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the process of identifying equilibrium points by setting derivatives to zero. There is a distinction made between finding equilibrium points and classifying them. One participant suggests linearizing the system near the equilibrium points and mentions specific points identified as (0, 0), (2, 2), and (-2, -2). The use of Jacobian matrices and eigenvalues is also introduced as a method for classification.
The discussion is active, with participants exploring different methods for classification. Some guidance has been provided regarding the linearization process and the use of eigenvalues to determine the nature of the equilibrium points. Multiple interpretations of the classification process are being examined without a clear consensus.
There is an emphasis on the urgency of the original poster's request due to an impending exam, which may influence the depth of discussion and the types of responses provided.
rakhi
Classify the equlibrium points of the system-Pls help me, its urgent!
Hi ,
I have my maths exam tomorow and I am not able to understand the concept to classify the equilibrium points of a system.. I will be grateful if anyone could help me with this problem
Classify the equilibrium points of the system :
x'= )y^3)-4x
y'= (y^3)-y-3x
The equilibrium points are where the derivatives are zero, right? So what happens if you put the derivatives as zero in those equations?
Hello,
He's asking how to classify them, not how to find them.
rakhi said:
Hi ,
x'= )y^3)-4x
y'= (y^3)-y-3x
The first thing to do is "linearize" the system close to each equilibrium point. I presume you have found that the equilibrium points are (0, 0), (2, 2), and (-2, -2).
If x and y are close to 0, then, since powers get smaller and smaller close to 0, the linearization is x'= -4x, y'= -y- 3x. You could actually solve the equations to get [itex]x= Ce^{-4t}[/itex], [itex]y= De^{-t}- Ce^{-4t}[/itex] and see from that that both x and y go to zero as t goes to infinity. Another, perhaps simpler, method is to think of it as a matrix equation:
[tex]\frac{d}{dt}\begin{pmatrix}x(t) \\ y(t)\end{pmatrix}= \begin{pmatrix}-4 & 0 \\ -3 & -1\end{pmatrix}\begin{pmatrix}x \\ y\end{pmatrix}[/tex]
and observe that its eigenvalues, which are -4 and -1, are both negative.
In fact the simplest thing to do is to form the "Jacobian" of the left side,
[tex]\begin{pmatrix}\frac{\partial y^3- 4x}{\partial x} & \frac{\partial y^3- 4x}{\partial y} \\ \frac{\partial y^3- y- 3x}{\partial x} & \frac{\partial y^3- y- 3x}{\partial y}\end{pmatrix}= \begin{pmatrix}-4 & 3y^2 \\ -3 & 3y^2- 1\end{pmatrix}[/tex]
and then set x= 0,y= 0, x= 2, y= 2, x= -2, y= -2, to find the eigenvalues.
For example, setting x= 0, y= 0 gives
[tex]\begin{pmatrix} -4 & 0 \\ -3 & -1\end{pmatrix}[/tex]
which has eigenvalues -4 and -1 as before.
Setting x= 2, y= 2 gives
[tex]\begin{pmatrix}-4 & 12 \\ - 3 & 11\end{pmatrix}[/tex]
which has eigenvalues 8 and -1. Since one eigenvalue is positive and the other negative, this is a saddle point. Further, (1, 1) is an eigenvector for eigenvalue 8 and eigenvector (2, 1) associated with eigenvalue -1. So if you draw lines through (2, 2) in those directions, you could get a rough graph of the solutions in that region.
Setting x= -2, y= -2 gives the same matrix (because there is no x and y is squared) so the same eigenvalues and eigenvectors. (-2, 2) is also a saddle point.
