FREEMAN ION SOURCE Design and Optimization for Increased Beam Density
  • Thread starter Thread starter david allen
    Ion Source
The discussion focuses on the design and optimization of the Freeman Ion Source to achieve increased beam density, specifically for a BS thesis. Key references include "Freeman and Bernas Ion Sources" by Marvin Farley, Peter Rose, and Geoffrey Ryding, which covers essential aspects such as plasma potentials, current balance, and maintenance issues. The user seeks detailed specifications like filament length and optimal distances between components, indicating a need for practical design guidelines in ion source construction.
  • Understanding of ion source design principles
  • Familiarity with plasma physics concepts
  • Knowledge of maintenance practices for ion sources
  • Experience with control systems in ion implantation
  • Research optimal filament lengths for Freeman Ion Sources
  • Investigate the effects of different materials in arc chambers
  • Study maintenance techniques for ion source components
  • Explore control systems used in Bernas and Freeman Ion Sources
Students and researchers in the field of ion source technology, particularly those focusing on beam density optimization and ion implantation applications.
david allen
Hi
I am searching on freeman ION SOURCE for my BS thesis. I have lots of problem about the material of the FREEMAN ION SOURCE and sizes of all the part to have the best design and better beam density. I need some details. Any help would be appreciated.
There are several textbooks on Ion Sources, but they tend to be rather expensive.
8. Freeman and Bernas Ion Sources (Marvin Farley, Peter Rose, and Geoffrey Ryding).
8.1 Introduction.
8.2 The Freeman Ion Source.
8.3 The Bernas Ion Source.
8.4 Further Discussion of the Source Plasma.
8.4.1 Plasma and Sheath Potentials.
8.4.2 Effect of Sputtering on the Plasma.
8.4.3 Ion Heating of the Cathode and Anticathode in the Bernas Source.
8.4.4 Current Balance in the Freeman Source.
8.4.5 Current Balance in the Bernas Source.
8.5 Control Systems.
8.5.1 Freeman and Bernas Controls.
8.5.2 Bernas Indirectly Heated Cathode.
8.6 Lifetime and Maintenance Issues.
8.6.1 Use of BF3.
8.6.2 Use of PH3, AsH3, P4, and As4.
8.6.3 Use of Sb, Sb2O3, and SbF3.
8.6.4 Use of SiF4 and GeF4.
8.6.5 General Guidelines for the Use of Other Organic and Inorganic Compounds.
8.6.6 Electrode Cleaning and Maintenance.
8.6.7 Insulator Cleaning and Maintenance.
from The Physics and Technology of Ion Sources, 2nd, Revised and Extended Edition, Ian G. Brown (Editor), Wiley, October 2004 - US$300
http://www.wiley.com/WileyCDA/WileyTitle/productCd-3527404104,descCd-tableOfContents.html
Sample from text - http://books.google.com/books?id=jOlKdGPBpD0C&pg=PA134&
Paper - "Ion Sources For Commercial Ion lmplanter Applications" mentions Freeman sources
http://accelconf.web.cern.ch/accelconf/p91/PDF/PAC1991_2088.PDF
I really appreciate for your replay. I have got this book that is great but it did not mention for sort of details such as what is the best length of FILAMENT or the best distance between chamber and filament and the best element for using in arc chamber.
thank you
  • · Replies 25 ·
  • · Replies 24 ·
