| New Reply |
Calculate the density at which the available thrust is equal to the minimum drag |
Share Thread | Thread Tools |
| Oct31-12, 05:23 PM | #1 |
Calculate the density at which the available thrust of a jet propelled aeroplane is equal to the minimum drag for the full fuel load case. Use the simplest assumption for the variation of engine thrust with density.
Wing area, S = 29.5 Weight, W = 88000 CD,0 = 0.02 k = 0.044 Max thrust (at sea level) = 16000N CT = 1.7*10^-4 I use the formula Dmin = 2((CD,0*k)^0.5)*W = 5221N The problem I have is that I can't work out the density without the velocity but there is no way to relate velocity to drag without density. Where do I go from here? |
| Nov1-12, 07:44 PM | #2 |
Recognitions:
If you care to revise your posting, supplying the units and explaining what each of the three co-efficients is, I'll take a look at your problem.
| New Reply |
| Tags |
| aerodynamics, jet plane, minimum drag, thrust |
| Thread Tools | |
Similar Threads for: Calculate the density at which the available thrust is equal to the minimum drag
| Points of action for thrust and drag forces and lift-drag ratio | Aerospace Engineering | 1 | ||
| Minimum thrust of engines at lift-off | Introductory Physics Homework | 2 | ||
| Speed of Minimum Drag | Advanced Physics Homework | 0 | ||
| Thrust,drag and lift on airplane Question | Advanced Physics Homework | 2 | ||
| calculate hydrostatic thrust | Engineering, Comp Sci, & Technology Homework | 2 | ||
