Axial rotation of a magnetic field detection
The discussion centers on the detection of a magnet spinning on its axis, specifically regarding the behavior of its magnetic field and the implications for induced electric fields. Participants explore theoretical and practical aspects of this phenomenon, including comparisons with electric coils and the nature of magnetic field lines.
  • Steve Stillman questions whether a spinning magnet can be detected when its magnetic axis aligns with its spin axis, noting that the magnetic field lines may not change in flux level at any point in space.
  • Some participants suggest that a moving magnetic field generates an electric field, but the detection of this field may depend on the configuration of the circuit used.
  • One participant proposes that a circuit loop with one moving wire and one stationary wire could detect the electric field generated by the spinning magnet.
  • Another participant emphasizes that on the axis of rotation, the velocity of the magnet is zero, and thus the electric field generated by the magnetic field lines increases with distance from the axis.
  • There is a discussion about whether the magnetic field rotates with the magnet, with some electrical engineers asserting that it does, while some physicists argue that magnetic field lines are merely a mathematical construct and do not physically rotate.
  • Steve Stillman expresses skepticism about the ability to detect the flux movement of a spinning magnet, referencing past discussions with professors and the lack of coverage in physics literature.
  • One participant mentions a derivation involving relativity that claims to provide clarity on the issue, suggesting that it is a well-established topic in physics literature.
Participants express differing views on whether the magnetic field rotates with the magnet and the implications for detection. There is no consensus on the ability to detect a spinning magnet's field or the nature of magnetic field lines.
Participants highlight the complexity of the topic, including the dependence on specific configurations of wires and the interpretation of magnetic field lines. The discussion remains unresolved regarding the detection methods and theoretical implications.
steve stillman
Since the archive didnt have an answer or these keywords, is there any way to detect a magnet spinning on its axis so the magnetic field is rotating axially and lines of flux are rotating around but nowhere in space is the flux level changing? I've heard rummors over the years. This is not the Homopolor motor which is quite different. Seems like the lines of flux cut a nearby coil but since the level doesn't change there is no induced current. How about the inducing of spin of another nearby magnet due to meshing lines?
A related question is to substitute an electric coil and spin it. Then the magnetic lines do not rotate as the coil rotates and there is the same question of detection but less hope.
Thanks, and I've learned a lot from this site and it runs fast.
Steve Stillman,
Steve Stillman,
Here's one way of looking at it:
A moving magnetic field generates an electric field. At the center of the axis, the magnetic field is not moving, but at any point that's not on the center, you'll have a tangential velocity of w*r, and this will generate an electric field in the usual manner.
The secret to detecting this electric field is to not use a coil of constant area. If you take a coil of a fixed area and move it, flux leaves the loop just as fast as it enters, and there is no induced voltage. Another way of looking at it is that the leading part of the loop generates a voltage, but the trailing part of the loop generates an equal and opposite voltage, so there is no net voltage across the loop.
But if you form a circuit loop consisting of one moving wire, and one stationary wire, and whatever wires you need to complete the circuit, you will detect an electric field. The area of the loop will not be constant, and you'll have a net flux through the loop.
If you draw this situation out in detail (one moving wire, one stationary wire), you will have a homopolar generator. Usually one or both of the wires is replaced with a disk.
Clarification of my question
I should clarify my question. I can detect a magnet presence with a wire cutting the lines, yes, but can I detect a spinning magnet that spins with the axis if its flux the same as the spin axis? And then, is a spinning electrically generated magnetic field any different.
Steve Stillman
Steve Stillman
I'm not sure I understand the question. On the axis of rotation, the velocity of the magnet is zero, and it doesn't matter whether or not the magnet is spinning. As you move some distance 'r' away from the axis of rotation, the magnet (and the magnetic field lines) have some velocity 'v'. These moving magnetic fields create electric fields that are at right angles to both the velocity, and the magnetic field. This means that the electric field points in the direction of increasing 'r', and that the electric field at r=0 is zero, it increases linearly with 'r'.
To generate a net voltage in a loop of wire from the moving magnetic field, you still need to have one wire moving and one wire stationary, otherwise there is no next flux, just as in the case where the wires were moving. One wire must always move, one wire must always be stationary, no matter which viewpoint you look at the system from.
It may be simpler to think of measuring the electric field directly, by measuring the acceleration of a free standing charge. In this case, (as I said before) you will find that the electric field is zero directly on the axis of rotation, and it points radially, increasing as you increase 'r'.
The question I am asking is not the obvious question. Yes I know that time variant magnetic flux induces a current in a loop of wire or a moving wire cutting lines generates a current...My question, again, is "can I detect a spinning magnet that spins on its magnetic axis"? There were rumors that it was possible talking with my professors way back in college. I've never seen any discussion of it in any physics book. Some I've talked too think a magnet drags its lines around with the matter, but an electrically generated magnetic field is unable to do so...but how to detect the flux that moves or doesn't move?
Thanks.
Steve Stillman
People have been arguing, on-and-off, about this for years. Many electrical engineers insist that the magnetic field rotates with the magnet. Physicists take the view that, since the magnetic field lines are merely a mathematical artifice, it is meaningless to talk about their rotation.
Steve Stillman,
Sure. I did a derivation right here
http://www.geocities.com/physics_world/em/rotating_magnet.htm
One must use relativity to get the correct answer. This is textbook stuff. Not something that I see debated in the physics literature. But I had to see how things were working, hence the diagrams.
Pete
  • · Replies 42 ·
  • · Replies 19 ·
