Roots lying between the roots of a given equation
  • Thread starter Thread starter utkarshakash
    Roots
The discussion revolves around determining the values of 'a' for which the roots of the quadratic equation \(x^2-2x-(a^2-1)=0\) lie between the roots of another quadratic equation \(x^2-2(a+1)x+a(a-1)=0\). The participants explore conditions related to the discriminants and the positioning of the roots.
  • Participants discuss the conditions for the discriminants to be non-negative and the implications of the roots' positions. There is a focus on whether the average of the roots is sufficient for determining their placement relative to each other.
The conversation is active, with participants questioning assumptions about the roots and their relationships. Some participants suggest expressing the roots in terms of 'a' for clarity, while others verify their findings against the expected results.
There is mention of specific values of 'a' and conditions under which the roots are evaluated, including a reference to a potential error in understanding the average of the roots versus their individual placements.
utkarshakash
For what real values of 'a' do the roots of the equation [itex]x^2-2x-(a^2-1)=0[/itex] lie between the roots of the equation [itex]x^2-2(a+1)x+a(a-1)=0[/itex]
The required conditions are
[itex]\large D_1\geq0[/itex]
[itex]\large D_2\geq0[/itex]
[itex]\large R_1<\dfrac{-2}{2}<R_2[/itex]
where
[itex]D_n=[/itex]Discriminant of nth equation and [itex]R_m=[/itex] mth roots of the latter equation
Solving simultaneously the above inequalities and taking intersection
[itex]a\in \left(\frac{-1}{3},0\right)[/itex]
But the correct answer is
[itex]a\in \left(\frac{-1}{4},1\right)[/itex]
Where does the -2/2 come from? Shouldn't there be an 'a' in there?
Sorry I made a mistake. It must be 2/2 (-b/2a)
But that's only the average of the roots. You need the condition that each root individually is in that range.
You are not understanding. Its not the average of the roots. Its the x-coordinate at which the minimum value of function occurs.
OK, but why is that interesting?
Express the roots in terms of 'a' first. The non-negativity of the discriminants is not enough.
If you are right, both roots of the first equation lie between or equal to one of the roots of the second equation in case a=-1/3. Is it true?
ehild
ehild
I started by finding roots then substituting them for x in the latter equation and setting them <0. The answer which I get is correct. So, no worries!
Did you get [itex]a\in \left(\frac{-1}{4},1\right)[/itex]? That is the correct answer, I have checked. Why should the roots be negative? Try with a=0.5. Do the roots of the first equation lie between the roots of the second one?
ehild
Yes i got that answer.
  • · Replies 22 ·
  • · Replies 20 ·
  • · Replies 27 ·
  • · Replies 21 ·
