Is There a Standard Notation for Matrix Rows and Columns?
  • Context: Undergrad
  • Thread starter Thread starter Max.Planck
    Matrix Notation
The discussion revolves around the notation used to denote the i-th row and j-th column of matrices. Participants explore various notational conventions and their applicability in mathematical proofs and contexts.
  • Some participants mention that there are several notations for denoting the i-th row and j-th column of a matrix, referencing a Wikipedia article for context.
  • One participant suggests using the notation ##a_{i,*}## for the i-th row and proposes that rows and columns could be represented as vectors.
  • A participant expresses a need for notation to indicate the i-th column of matrix A and the j-th row of matrix B in a proof.
  • Another participant shares their personal notation, using ##A_{\bullet i}## for the i-th column and ##A_{j\bullet}## for the j-th row.
  • It is noted that there is no universally accepted standard notation for matrix rows and columns, with some journals having specific style guides.
  • A participant cites that the main ISO standard for matrix notation specifies bold-face type, but does not establish a standard notation for rows and columns.
Participants generally agree that there is no standard notation for matrix rows and columns, but multiple competing notational conventions are presented without consensus on a single preferred method.
Limitations include the lack of a universally accepted notation and the dependence on specific contexts or style guides that may vary across journals.
Max.Planck
Is there notation to denote the i-th row of a Matrix or j-th column?
Yes - several. What was the context?
http://en.wikipedia.org/wiki/Matrix_(mathematics)#Notation
eg. if ##a_{i,j}## denotes the i/jth element of ##\mathbf{A}## then ##a_{i,*}## is a common way to denote the ith row of ##\mathbf{A}##... or maybe the rows and columns would be represented as vectors.
For example in a proof I would like to say:
[itex]\exists i[/itex] such that the i-th column of A = the j-th row of B, basically I'm looking for the notation of i-th column, and j-th row.
I sometimes use the notation [itex]A_{\bullet i}[/itex] to denote the i-th column and [itex]A_{j\bullet}[/itex] to denote the j-th row.
Is there a standard for notation?
No - as the wikipedia article (see link above) points out there is no standard (i.e. ISO standard) notation. Some journals may specify a particular form in their style guides. afaik the main ISO standard for matrix notation specifies bold-face (poss bf-italics).
Per your example: one would most commonly write something like:$$\mathbf{A},\mathbf{B}\in \mathbb{M}_{m\times n}; a_{i,j}\in \mathbf{A}, b_{i,j}\in \mathbf{B}: a_{i,*}=b_{*,i}$$... and be fairly confident of being understood to mean that the ith row of A is the same as the ith column of B (pretty much the transpose but a fair example and you can have different functions of the row/column numbers.)
