Algebraic vector problems (planes, cross products etc)
The discussion focuses on solving algebraic vector problems involving cross products and orthogonal vectors in ℝ3. Participants analyze the equations derived from the vector u = λa + μb, demonstrating that [(b × u) · n]/[(b × a) · n] = λ and [(a × u) · n]/[(a × b) · n] = μ, where n is the normal vector to the plane spanned by vectors a and b. The challenge of constructing an orthogonal vector b' to a within the same plane is also addressed, with suggestions to utilize the vector (a × b) × a for this purpose.
  • Understanding of vector algebra, specifically cross products.
  • Familiarity with vector spaces and basis vectors in ℝ3.
  • Knowledge of normal vectors and their significance in geometry.
  • Ability to manipulate scalar and vector equations.
  • Study the properties of cross products in vector algebra.
  • Learn about orthogonal basis vectors and their applications in linear algebra.
  • Explore the geometric interpretation of normal vectors in three-dimensional space.
  • Investigate the vector triple product and its implications in vector calculations.
Students and professionals in mathematics, physics, and engineering who are dealing with vector analysis, particularly in the context of linear algebra and geometry.
PedroB
1. A vector u is given by u = λa + μb, where λ, μ are elements of ℝ. Calculate axu and bxu and show that:
[itex][(b χ u).n]/[(b χ a).n][/itex] = λ
and
[itex][(a χ u).n]/[(a χ b).n][/itex] = μ
(In any circumstance when I have omitted the underlining it is for convenience purposes, a, b, n and u are still vectors.)
2. The vectors a and b form a set of basis vectors for P1 (A plane spanned by vectors a and b). However it is often desirable to use a set of orthogonal basis vectors.
Construct a vector b' that is in P 1 and orthogonal to a.
We are told that a and b are vectors in ℝ3, and that they are not parallel or anti-parallel. n is the normal vector to plane P1.
1. n= a x b
a x b = a x (aλ x bμ)
= a x bμ
= nμ
∴[itex](a χ u)/n[/itex] = μ
[itex](a χ u)/(a χ b)[/itex] = μ
The same can be applied for obtaining an equation with λ. The problem arises out of the fact that I wouldn't know how to incorporate the '.n' portion to the numerator and denominator (though it seems quite obvious that their cancellation would yield the above equation, it must serve some purpose).
2. I can't find any sort of methodology that would yield a vector, b', perpendicular to a in P1 when only given the information above. I would assume it has something to do with question 1 (I could be wrong), though I can't see how they relate to one another.
Thanks in advance for any help.
Mod note: I tweaked what you wrote to make it more readable. In particular, I replaced the character you used for the cross product (Greek letter chi?) with X.
[(b X u) ##\cdot## n]/[(b X a) ##\cdot## n] = λ
and
[(a X u) ##\cdot## n]/[(a X b) ##\cdot## n] = μ
What is n?
PedroB said:
(In any circumstance when I have omitted the underlining it is for convenience purposes, a, b, n and u are still vectors.)2. The vectors a and b form a set of basis vectors for P1 (A plane spanned by vectors a and b). However it is often desirable to use a set of orthogonal basis vectors.
1. n= a x b
= a x bμ
= nμ
∴[itex](a X u)/n[/itex] = μ
[itex](a X u)/(a X b)[/itex] = μ
2. I can't find any sort of methodology that would yield a vector, b', perpendicular to a in P1 when only given the information above. I would assume it has something to do with question 1 (I could be wrong), though I can't see how they relate to one another.Thanks in advance for any help.
and
1. n= a x b
= a x bμ
= nμ
But of course, you can't divide by a vector. What you do have correct is$$
a\times u =\mu(a\times b)$$with vectors on both sides. You can dot both sides of that equation with ##n##, giving$$
(a\times u)\cdot n = \mu(a\times b) \cdot n$$Now this is a scalar equation which you can solve for ##\mu##. Do you see why ##(a\times b) \cdot n\ne 0\ ##, allowing you to divide by it?
And you do the similar thing to solve for ##\lambda##.
For 2 think about where the vector ##(a \times b)\times a## would be.
  • · Replies 21 ·
  • · Replies 18 ·
