Motion in one dimension problem
  • Thread starter Thread starter Ammar w
    Dimension Motion
The problem involves an object moving along the x-axis described by a quadratic equation. Participants are tasked with calculating average and instantaneous speeds and accelerations at specific times, as well as determining when the object comes to rest.
  • Participants discuss the calculation of total distance versus displacement in relation to average speed and average velocity. There is a focus on the definitions and distinctions between speed and velocity.
Some participants have provided guidance on calculating average speed and have engaged in clarifying the differences between average speed and average velocity. There is ongoing debate regarding the interpretation of distance and displacement in the context of the problem.
Participants are exploring the implications of the object's motion as described by the equation, with specific attention to the increasing nature of position x over time. There is uncertainty about the definitions being applied and the calculations involved.
Ammar w
An object moves along the x-axis according to the equation x = 3.00t2 - 2.00t + 3.00 , where x is in meters and t is in seconds.
Determine :
(a) the average speed between t = 2.00 s and t = 3.00 s.
(b) the instantaneous speed at t = 2.00
(c) the average acceleration between t = 2.00 s and t = 3.00 s.
(d) the instantaneous acceleration at t = 2.00 s
(e) at what time is the object at rest?
average speed = [itex]\frac{d(total distance travelled)}{\Delta t}[/itex]
instantaneous speed = [itex]\frac{dx}{dt}[/itex]
[itex]\overline{a}[/itex] (average acceleration) = [itex]\frac{\Delta v}{\Delta t}[/itex]
a (instantaneous acceleration) = [itex]\frac{dv}{dt}[/itex] = [itex]\frac{dx^2}{dt}[/itex]
(a) I couldn't calculate the total distance.
(b) instantaneous speed = instantaneous velocity = [itex]\frac{dx}{dt}[/itex] = 6.00t - 2.00
instantaneous speed at t=2.00 = 6.00(2)-2.00 = 10 m/s
(c) [itex]\overline{a}[/itex] = [itex]\frac{\Delta v}{\Delta t}[/itex] = [itex]\frac{vf-vi}{1}[/itex] = [itex]\frac{v(3)-v(2)}{1}[/itex] = [itex]\frac{16-10}{1}[/itex] = 6 m/s2
(d) a = [itex]\frac{dx^2}{dt}[/itex] = 6 => a at 2.00s = 6 m/s2
(e) the rest means that v = 0
=> 6t-2=0
=>t=0.33 s //it seems wrong.
Looks like you did pretty well.
The total distance? x= distance,
so calculate x at 3 secs minus x at 2 secs
thanks
but x at 3 minus x at 2 is the displacement which we use to calculate the average velocity not average speed. right??
Speed is just (absolute) velocity.
I think no.\
the average velocity is different from average speed
average velocity = dispacement/time
average speed = distance/time
sometimes average velocity is zero (when a particle moves and return to the starting point) where the average speed is a positive number.
in this problem I think the distance is like what you said = x at 3s - x at 2s because the position x is always increasing (from the equation)
Speed is defined as the scalar magnitude of the velocity vector. Since this is a one dimensional problem it simply becomes the absolute velocity.
Fact.
sorry, still not convinced!
  • · Replies 21 ·
  • · Replies 29 ·
