Mastering Physics: Ball hits wall Elastically
The discussion revolves around a physics problem involving an elastic collision between a ball and a vertical wall. The original poster is tasked with determining the final angle of the ball's velocity vector with respect to the negative y-axis after the collision, given specific parameters such as the mass of the ball, its initial velocity, the angle of incidence, and the duration of the collision.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the conservation of momentum and energy in elastic collisions, questioning how to apply these principles to the x and y components of the velocity. The original poster expresses confusion about the components and how to calculate them, while others suggest using trigonometry to resolve the velocity into its components.
The discussion is ongoing, with participants providing hints and guidance regarding the conservation laws and the need to analyze the components of momentum separately. There is an acknowledgment of the complexities involved, particularly regarding the effects of the wall and gravity, but no consensus has been reached on the specific calculations or final angle.
The original poster indicates a lack of familiarity with physics concepts, which may affect their understanding of the problem. There is also a mention of the collision being idealized, with negligible friction and no spinning of the ball, which may influence the assumptions made in the discussion.
RhysticGenesis
First off let me say I am completely stumped. I don't remember teacher teaching this, and its definitely not in book(I went through it 3 or 4 times) and its not even the same book mastering physics uses...
The Question is :
What is the final angle that the ball's velocity vector makes with the negative y axis?
The Given are:
A ball of mass m moving with velocity v_i strikes a vertical wall. The angle between the ball's initial velocity vector and the wall is theta_i. The duration of the collision between the ball and the wall is Deltat, and this collision is completely elastic. Friction is negligible, so the ball does not start spinning. In this idealized collision, the force exerted on the ball by the wall is parallel to the x axis.
an image cna be found here: http://session.masteringphysics.com/problemAsset/1010992/25/MLM_e2.jpg
I have no clue on how to solve this... all I do know however is that physics is not my subject heh. Can anyone help lead me in right direction? (keep in mind I am seriously not good in physics [Math yes] physics no so try and keep it dumb if you can? I want to know how to get the answer..well I have to know actually
Edit: Ok I know this much I have to find the Y component and X component and stick them together thing is... how? I was thiking it has to be sin(Theta_i) to get the piece that is rquired for the distance the ball is from the wall?
Since the collision is elastic, you know energy is conserved. Hint: Is momentum conserved? (Remember that momentum is a vector; consider x and y components separately.)
The momentum would be conserved wouldn't it? Well not completely though? Wouldnt a lot be lost because of the wall? I don't understand where you are pointing me with this? I know I have to treat x and y comp separately but I don't truly know what the heck an x and y component is in this prob maybe that's where my problem lies?
I'll rephrase my question: Is momentum conserved in the x-direction? ... the y-direction? (Why?)
Also: What's the final speed?
Now write an equation for conservation of momentum. (Use a little trig to find the x and y components of the velocity.)
As Doc Al pointed out, momentum is a VECTOR. Initially, the momentum vector is pointed TOWARD the wall (because the ball is moving toward the wall). Is it pointed that way after the ball bounces? But it is true that energy is conserved.
Don't forget to deal with gravity. It is an elastic collision, but the magnitude of the velocity before and after the collision is not the same (deal with the x and y components separately).
12K
  • · Replies 31 ·
