How Do You Correctly Derive (-x^2/18)?
  • Thread starter Thread starter Hemolymph
    Derivative
The discussion revolves around finding the derivative of the function (-x^2/18). Participants are exploring different methods for differentiation, including the quotient rule and the power rule, while addressing common mistakes in applying these rules.
  • Some participants suggest rewriting the function to simplify the differentiation process. Others question the application of the quotient rule and discuss the power rule as an alternative. There are attempts to clarify the correct use of differentiation rules, including the constant multiple rule.
The discussion is active, with participants providing guidance on differentiation techniques. There is recognition of mistakes made in applying the rules, and some participants express a clearer understanding as the discussion progresses. Multiple interpretations of the problem and methods are being explored.
There are mentions of confusion regarding the application of the quotient rule when the denominator is a constant, as well as the importance of recognizing the derivative of constant terms.
Hemolymph
Can someone please show me how to get the derivative of (-x^2/18). I know the answer is x/9 but I use the quotient rule and keep getting (x^2-36x)/18^2
Thanks b
Instead of using the quotient rule, try writing the function as:
[itex]\frac{1}{18}x^2[/itex]
Now it is just a power rule derivative. Does that help?
Not that the quotient rule doesn't work, though. From your answer, it looks like you're doing it incorrectly. Remember that the quotient rule is:
[tex]\frac{d}{dx}\frac{f(x)}{g(x)}=\frac{g(x)f'(x)-f(x)g'(x)}{(g(x))^2}[/tex]
So I did (1/18)(x^2)
To get 2x(1)+(1/18)(x^2)
2x+(x^2/18)
(36x+x^2)/18
what can i do after that step?
You're using the power rule incorrectly also. The power rule is:
[tex]\frac{d}{dx}cx^n=ncx^{n-1}[/tex]Edit: Ah, it looks you are trying to do the product rule. Remember that if you have any constant times x or x divided by a constant, you can use the power rule instead of the product or quotient rules.
Remember that the derivative of a constant term is 0, not 1!
Still, once again, the power rule does work in this case. It is:
[tex]\frac{d}{dx}f(x)g(x)=f'(x)g(x)+f(x)g'(x)[/tex]
whoops it should have been -x^2+36x/18^2 for the quotient rule
Yea thanks I just had a small mental break down was making stupid mistakes
I get (18x^2+2x)/18
Let's try this first:
What is [itex]\frac{d}{dx}x^2[/itex] ?
it would be 2x
2x+(x^2/18)
(36x+x^2)/18
What is
[tex]\frac{d}{dx} \left(\frac{1}{18}\right) \, ?[/tex]
RGV
Ray Vickson said:
What is
RGV
a constant so one
The derivative of a constant is 0.
WOW I am such a fool...
alright I got it now...(2x/18)=x/9
Thanks everyone for your help much appreciated
A couple more points that weren't brought up in this thread:
1. You should never use the quotient rule if the denominator is a constant. It's not wrong to use the quotient rule, but it's more complicated, which makes it more likely that you will make a mistake.
For example, if f(x) = x2/4, write this as (1/4)x2 and use the constant multiple rule, which says that d/dx(k*f(x)) = k*d/dx(f(x)).
Using this rule we get f'(x) = (1/4) * d/dx(x2) = (1/4) * 2x = x/2
2. You should never use the product rule if one factor is a constant. Instead, use the constant multiple rule. It would not be incorrect to use the product rule, but as before, it's more complicated, so you are more likely to make a mistake.
For example, if g(x) = 10 * tan(x), then g'(x) = 10 * d/dx(tan(x)) = 10 * sec2(x).
Thanks that definitely helped me
  • · Replies 25 ·
  • · Replies 24 ·
  • · Replies 29 ·
  • · Replies 23 ·
