New Reply
Basic Kinematics Question
Share Thread Thread Tools
Nov4-12, 07:40 PM   #1
The equation
v22 = vo2 + 2aΔy
is used to determine the change in position, acceleration, or velocity of a particle under the influence of a quadratic force.
on earth, the acceleration value in this equation would, under normal circumstances, be
a= -9.8 m/s2.
so, this substitutes into
v22 = vo2 + -19.6Δy
In this
Δy = v22 - vo2 / -19.6
Lets now assume that v22 is 0, the crest of a projectiles motion.
Δy = 0 - vo2 / -19.6
If the objects initial v is facing upwards, then obviously the net Δy would be positive.
Now, keeping all conditions the same, lets assume that the acceleration is 9.8m/ss upwards
This would yield
Δy = 0 - vo2 / 19.6
Δy would thus be negative, and the object would be thrown downwards, accelerating upwards.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Nov4-12, 10:49 PM   #2
Recognitions:
Homework Helper Homework Help
I'm sorry - was there a question in all that?
Nov4-12, 11:15 PM   #3
Recognitions:
I just want to go through your reasoning to make sure I follow:
Quote by KingKai View Post
The equation
v22 = vo2 + 2aΔy
That would be a net unbalanced force which is constant.
a= -9.8 m/s2.
"normal circumstances" being, +y = "upwards", Δy<<REarth, and gravity is the only force acting on the object.
v22 = vo2 + -19.6Δy
Your value has changed somehow [x2 of course] ... better to put g=9.8N/kg so a=-g so it does not matter what units you want to work in just yet... you get:$$v_2^2=v_0^2-2g\Delta y$$
In this
$$\Delta y = \frac{v_2^2-v_0^2}{-2g} = \frac{v_0^2-v_2^2}{2g}$$
$$\Delta y = \frac{v_0^2}{2g} > 0$$
No problems there.
All conditions?
So you put gravity upwards, and the final velocity is zero, but the assumption that the initial velocity is also upwards is incorrect - as you found below:
This would yield
Δy = 0 - vo2 / 19.6
$$\Delta y = \frac{0-v_0^2}{2g}=-\frac{v_0^2}{2g} < 0$$
Well ... you did specify that the final velocity is zero ... if the object were thrown upwards with an upwards acceleration, that would not be the case would it?
Nov6-12, 07:36 AM   #4
Recognitions:
Gold Membership Gold Member
When an object is thrown upwards, the acceleration is still 9.8 m/s2 downwards, but there is now an initial upward velocity imposed on the object which was simply not present in the case where the object was initially at rest and allowed to drop.
Nov7-12, 12:46 AM   #5
Recognitions:
Quote by Chestermiller View Post
Not the situation described though - here there was an initial speed.
New Reply
Thread Tools
Similar Threads for: Basic Kinematics Question
Thread Forum Replies
Need help with Basic Kinematics question! Introductory Physics Homework 8
Basic Kinematics Question Introductory Physics Homework 1
question on basic kinematics Introductory Physics Homework 7
Basic Kinematics question Introductory Physics Homework 6
Basic Kinematics Question(s) Introductory Physics Homework 4
