Probability of Finding a Random Walker in D Dimensions After N Steps
The discussion revolves around the probability of finding a random walker in D dimensions after N steps, starting from the origin. The problem involves concepts from probability theory and Markov chains, focusing on the walker’s movement to adjacent sites in a multi-dimensional space.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the implications of the Markov process on the probability calculations, questioning the dependency of the current state on previous states. There are discussions about partitioning steps across dimensions and the combinatorial aspects of reaching target coordinates. Some participants suggest considering the number of ways to reach a certain position and the influence of spare steps on the probability.
The discussion is ongoing, with various interpretations and approaches being explored. Some participants have offered alternative methods for calculating probabilities, while others express confusion regarding the application of Markov chain properties and the correct formulation of the problem. There is no explicit consensus yet, but productive lines of inquiry are being pursued.
Participants note potential misunderstandings regarding the nature of the Markov chain in this context, particularly concerning its homogeneity and the assumptions about step dependencies. There are also mentions of specific cases where the number of steps may not align with the target position, indicating a need for careful consideration of the problem's constraints.
fluidistic
Hi guys, I'm absolutely desperate on the following problem:
Consider a random walker who can make steps only to neighbor sites in "D" dimensions where D is an arbitrary natural number. Assume that the distance between 2 adjacent sites is the same for all sites and that the probability for the walker to choose between any adjacent site is the same. Let [itex]\vec r[/itex] be a particular site and N be the number of steps the walker has done.
What is the probability to find the random walker at [itex]\vec r[/itex] after N steps if he starts initially at the origin?
Answer to this question using:
1)the assumption that the walk can be described as a Markov chain in D dimensions.
2)the distribution function of the displacement of the walker after N independent steps, [itex]\vec r = \vec r _1 + ... + \vec r _N[/itex].
Probably a lot! Not really sure.
I tried part 1) so far but did not go far at all.
I know that the probability to choose any adjacent site is [itex]\frac{1}{2D}[/itex] where D is the dimension of the space the walker walks in.
So they are asking me [itex]P_N(\vec r)[/itex]. I'll use the notation [itex]\vec r=r_1 \hat x_1 +... + r_D \hat x_D[/itex]; that's the position of the walker after N steps.
I have the initial condition that [itex]P_0(\vec r )=\vec 0[/itex]. Since I'm given an initial condition on [itex]P_N(\vec r )[/itex] and that I'm asked to find [itex]P_N (\vec r )[/itex] I can "smell" that I'll have to solve a differential equation or something like that, but I've no idea how to find it.
Now I know that for a Markovian process, the probability that the walker will go to say [itex]P _N(\vec r)[/itex] does not depend on its past but only on its present. Namely only on the "state" [itex]P_ {N-1} (\vec l )[/itex] where [itex]\vec l[/itex] is the site of the walker prior to [itex]\vec r[/itex].
If I'm not wrong, then, I guess [itex]P_N (\vec r)=\frac{1}{2D} P_{N-1} (\vec l )[/itex].
But then if I take [itex]P_{N-1} (\vec l )[/itex] it will depend only on the previous state. In the end I get the wrong result that [itex]P_N ( \vec r ) = \left ( \frac{1}{2D} \right ) ^{N} P_0 (0)=\left ( \frac{1}{2D} \right ) ^{N}[/itex].
I know this result is wrong but I don't know what I'm doing wrong. Any help will be appreciated.
Your method didn't work because it only considered one possible prior state. There are 2D to sum over.
You could try assessing the number of ways N can be partitioned into the D dimensions, then how many ways each of those partitions can lead to the target coordinates. Or (almost the same?) get a recurrence relation based on number of steps available, number of dimensions, and remaining vector for those dimensions. I.e. knock off one dimension at a time.
First of all, thanks for the reply.
Hmm I don't really understand. Since it's a Markov process, the current state only depends on the last one, not on the previous ones.
Hmm I see, but would that be for part 2)? I don't see what it has to do with Markov chains (I'm explicitely asked to solve the problem by considering the process as a Markov chain in part 1).
I made a mistake in my first post, I reach that [itex]P_N(\vec r ,N | 0, 0) = \left ( \frac{1}{2D} \right )[/itex] instead of [itex]\left ( \frac{1}{2D} \right ) ^{N}[/itex]. That's still false because there's no dependency on [itex]\vec r[/itex] while there should.
Edit: Apparently I believe my result is wrong because I considered that the Markov chain is homogeneous while it seems it isn't.
A homogeneous Markov chain has the property that [itex]P(X_k=i_k | X_{k-1} =i_{k-1} )[/itex] does not depend on k. Well I'm confused. In the problem the Markov chain seems homogeneous... but then I reach a non sense answer.
Attempt for 2):
Let [itex]\vec r = \vec x_1 +... + \vec x_D[/itex]. Such that [itex]x_i[/itex] is the component of the vector r along the i'th dimension.
For any dimension i, there are [itex]{x_ i \choose N}[/itex] ways for the walker to get to [itex]\vec x_i[/itex] in N steps. And the probability to choose one particular way is [itex]\left ( \frac{1}{2D} \right ) ^N[/itex].
Since the position of the walker in any dimension has no influence whatsoever on its position along the other dimensions, I can safely write [itex]P _N ( \vec r ) = {x_1 \choose N} ... {x_d \choose N} \left ( \frac{1}{2D} \right ) ^N = \left ( \frac{1}{2D} \right ) ^N \sum _{i=1}^D \frac{N!}{(N-x_i )!x_i!}[/itex]. Does this look correct? I tried D=1 and I think it looked right; at least to me. What do you think? This would be my answer for the probability to find the walker at the position [itex]\vec r[/itex] after N steps.
fluidistic said:
Attempt for 2):
This is incorrect: for N = x_1 there is just 1 way to get from 0 to x_1 in N steps; for N = x_1 + 1, there is no way to get from 0 to x_1 in N steps; for N = x_1 + 2, there are 2 ways to get from 0 to x_1 in N steps, etc.
RGV
RGV
Woops I've got some latex typos. All my [itex]{n \choose k}[/itex] should be [itex]{k \choose n}[/itex]. Does this fix the problem?
Quite so, but you seem to be confusing "the probability of being at a certain point after N steps given it was at a certain neighbour after N-1" with ""the probability of being at a certain point after N steps (given only that it was at the origin at step 0)".
Isn't it clear that [itex]P_{N}(\vec{r})=\sum_{\vec{l} \in A(\vec{r})}P_{N-1}(\vec{l})/2D[/itex], where [itex]A(\vec{r})[/itex] is the set of neighbours of r?
In the OP, you don't say you have to "use" Markov chains, merely that you can assume it behaves like one. I don't know why they tell you that since it clearly does from the preceding description.
Wrt your later post, I don't understand how you got [itex]\left(^{x_i}_N\right)[/itex]. Maybe you meant [itex]\left(_{x_i}^N\right)[/itex], but I still don't see it. To reach xi in the i-direction there must be s steps in the 'wrong' direction and s+xi in the 'right' direction for any s<N. But the larger s is for one dimension, the less is left for the other dimensions, so it gets quite messy.
Try this: start by considering the case where N is only just large enough to reach r, i.e. no steps in the 'wrong' direction in any dimension. That's fairly easy. Then figure out the multiplier that arises from having spare steps, i.e. a larger N for the same r. Note that an odd number of spares will give you zero!
Ok thanks guys. I'll concentrate for now on the 2) part.
I totally overlooked that more steps in a dimension reduce the ones in the other as to reach N total steps...
Sorry: what I said above is incorrect. For n = x+2 there are not just 2 ways to get from 0 to x in n steps; there are C(n,n-1) = C(n,1) = n ways. In general, the number of ways of getting from 0 to x in n steps is
[tex]N_{n,x} = C(n, (n+x)/2) = {n \choose (n+x)/2},[/tex]
where it is understood that this equals 0 unless (n+x)/2 is an integer between 0 and n inclusive.
All this is treated beautifully in the marvelous book by W. Feller "An Introduction to Probability Theory and its Applications", Vol. I (Wiley, 1968), pp. 73-75 (an oldie, but an unbeatable classic).
RGV
RGV
Ok thank you infinitely for the information. I am going to take a look at this reference and post back in 1 or a few days.
